Old 04-08-2012, 08:36 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Trouble whit start. 5mt.
When i place my car before the winter. My car was running.
And now i have replace the cats, i have bougth this used.
One of this have a old lamba sensor. And i take on from my old cat.
and i have a bad gasked in the middel of the eksos systems. But i dont think this have some thig to doo whit the start problem.
The old cats i have stright pips but this leak. But when i drive the car before the Check Engine light came on about 3min driving.
And today the car start one time and then the Check engine light came one when the car start. And then i shut it down and try again. The car just run about 3sec and die.
Some one have a clue what this problem can bee?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 04-08-2012, 01:45 PM
Re: Trouble whit start. 5mt.
First, check the code. If the check engine light came on then there is a code stored.
Old 04-09-2012, 04:29 AM
Alex-svx's Avatar
Ok.
I have serch and find how to do this. So then i should try agin.
Thanks for the help so far.
Alexander (Norway)
My subarus:
Old 04-14-2012, 07:53 AM
Alex-svx's Avatar
The car will not start. I hve try to read the error code.
But the chekengine light only flash. will not stop.
And the lamba are also chage.
This is how the car act.
1. I put the key in on position and wait for the fuel pump to stop. (only way to start)
2. Then i turn the key to start.
3. So the car start at 1000rpm then it rev to 1900 then stop.
After doing this some times it smell gas in the garage. (no leak)
This happen every time. The fuel filter are also chage last winter.
I have had a accident whit the battery it ''blow'' whit start cable.
And the fuse line in the fuse box (in engine) goes. This have been replced.
After this the car wont go right. The fuel pump dont stop after the engine stop about 2sec.
Some one think what this can bee?
Alexander (Norway)
My subarus:
Old 04-14-2012, 07:37 PM
Hi Alex, if the jumper leads were connected back to front, there may be some damage to an electrical unit. It sounds like the ECU is turning on the pump to do the fuel prime, but then won't keep the pump running when it does start.
I would check the pump modulator under the rear deck to see if it is damaged, as the ECU runs it full speed, during the prime, but the modulator won't switch to low speed for normal idling.
The pumps ground wire is a yellow wire that runs to the momulator. Try just grounding the yellow wire to see if the pump will keep running.
Though the "After doing this some times it smell gas in the garage. (no leak)" is strange.
Old 04-14-2012, 08:47 PM
My thought was that maybe it's a spark problem and maybe the unburnt gas is just being exhausted out and that's what's causing the smell. But that doesn't really jive with the rest of the stuff he said.
Old 04-15-2012, 04:07 AM
Alex-svx's Avatar
Ok i can check the pump again. But when i start the engine the pump is running and after it die the pump also run. For about 1-2sec.
Alex
Alexander (Norway)
My subarus:
Old 04-15-2012, 11:55 AM
Alex-svx's Avatar
I will go down at the garage tomorrow.
But if i dont have no luck whit the fuel pump. Is the some thing else i can check? I dont have the car at my home so have a little trip to get there.
Thanks.
Alexander (Norway)
My subarus:
Old 04-16-2012, 09:38 PM
some easy checks to narrow down your search. won't make the car run but will lead you in the right direction.
spark: pull a coil and stick a screw driver in the end, prop it up so it is about a 1/2 inch from the engine so you can see and hear the spark. start the car and watch/listen. does the car stop before the spark or does the spark stop and the car dies? is the spark consistent?
fuel: clamp off the return fuel line with some vice grips and see if it runs longer. also jumper the pump as stated above. try unplugging one injector at a time and starting the car if one is being held open (by a short to ground from a melted wire) it will flood the car.
computer control: unplug the MAF before turning on the key and start the car. repeat with other sensors. if a sensor is shorted it can cause it to pull down the reference voltage and make the car stall.
simple stuff: check all of your fuses. make sure you have power at your coils and injectors when the car dies. you may have the start circuit intact but burned up part of the run circuit.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-18-2012, 07:43 AM
Alex-svx's Avatar
Hello.
Now i have try to jump the fuel pump. And the fuel pump is running the hole time. and i have try to take of the maff. And then the car is not starting.
All the spark plugs also work.
I have a exhaus leak under the car. Waiting for the gasked.
But it can maybe bee some noise form the intakemanifold(under)
Little hard to hear. And the fuelpressur regulator also work. hmm
Alexander (Norway)
My subarus:
Old 04-18-2012, 08:10 AM
Have you checked the timing belt?
( I was to busy to read through the thread)
Just a thought
Old 04-18-2012, 08:11 AM
An 02 sensor issue may be to blame. Try unplugging them and starting the car.
Old 04-18-2012, 11:02 AM
Alex-svx's Avatar
The o2 sensor is replaced.
Is not verry long that the timing belt was chaged. but the car have been stored whit no hood on the car (repaint projeckt).
Alexander (Norway)
My subarus:
Old 04-18-2012, 01:39 PM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Sorry to interrupt but you did the 5MT swap this winter, right? The car was starting before the swap but not after?
I have no clue when it comes to cars but troubleshooting I know
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-18-2012, 06:20 PM
Maybe i read it wrong but didnt the issue start after you replaced the sensor?
