Old 02-23-2012, 09:32 AM
Re: Maintainance and engine shape up
LAN doesn't stock those anymore. "NCA" = not currently available. :/
didn't see that. just had the link saved from my wish list. guess that's another thing to scratch off.
Old 02-23-2012, 09:43 AM
I'm sure you can still get some made by a company that does re-grinds. Profiles, I'm not sure about, but between searching old posts, and those companies you should be ok. Maybe LAN will be super nice and let you know the profile he was having them made to. Or you might be able to get him to make you some as a one-off if you send him the cams and pre-pay. Never hurts to ask.
Old 02-23-2012, 11:18 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Are the camshafts simply unavailable from Subaru or just very expensive?
And seriously, 133.000 kilometers, it's not a Ferrari.. Will it actually make a difference?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 02-23-2012, 12:59 PM
cthommes cthommes is offline
Considerable scope creep already underway here... I have no idea how a timing belt change discussion morphed into performance camshaft installation. Forget about camshafts!
Fix the timing belt / water pump as previously described, and any sources for leaks along the way. Then continue to enjoy driving the vehicle.
Old 02-23-2012, 01:01 PM
I thought it was 20, but subaruparts says you only need 16.
Yes, subaruparts is wrong here. You definitely need 20, unless you want 4 of them to leak...
Old 02-23-2012, 02:00 PM
Yeah, right...
And don't worry about the camshafts. They're fine. They were suggesting the possibility of upgrading, but after shipping that wouldn't be worth it at all.
Just do the timing belt, idlers,water pump, thermostat, cam/crank seals, valve cover gaskets and that's a good start. Also, a good idea would be to do the PCV valve and any vacuum lines. They are typically very brittle after nearly 20 years
Old 02-23-2012, 03:09 PM
Agreed, this is next on my list as well.
Old 02-23-2012, 04:43 PM
Ha mine too! Subarus going to be overwhelmed with all these vacuum line orders!
Old 02-23-2012, 05:16 PM
Vacuum lines? I was just going to use some bendy drinking straws...
Old 02-23-2012, 06:25 PM
Probably just as effective
Old 07-09-2012, 04:23 PM
theflystyle's Avatar
ive been through a lot of threads and this has been the most helpful one regarding to-dos during a timing belt change.
STICKY!
Old 07-25-2012, 07:43 AM
jetboy's Avatar
Ok, let's try to build a parts list. I will compile a "last post" when we're complete for future reference.
Apart from the pdf already supplied in this thread:
10105AA060 - Will this kit cover ALL gaskets and seals?
Timing belt:
http://www.ebay.com/itm/92-97-Subaru...ht_2674wt_1163
Is this a good kit? It's not OEM, did anyone try an of the "belt+pump" aftermarket kits?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 07-25-2012, 08:20 AM
Timing belt:
An OEM waterpump has been recommended in the past. But the rest of the kit will work. Try one of these instead:
http://www.ebay.com/itm/SUBARU-SVX-3...875017&vxp=mtr
I have used the "PCI" kits twice now and they work fine.
