Old 01-26-2012, 07:47 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
alternator replacement
so i put a new alternator in and i've ran to a problem
power steering, parking brake, brake, and battery lights are on in the dash, but they all are working properly
it all worked fine until i got home and had to park...the serpentine belt fell off then...had to put it back on cuz i don't have the strength to turn the wheel without that!
so what have i done wrong that all those warning lights are on?!
why did it fall?!
(it did charge the battery tho)
thanks in advance
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 01-26-2012, 07:58 PM
Re: alternator replacement
Make sure that you tightened everything in the tensioner assembly properly. I once made the mistake of forgetting to tighten the 12mm nut that holds the tensioner pulley tight. It backed itself off, and I had to put it and the belt back on. From the sounds of it, something definitely wasn't tight enough.
Old 01-26-2012, 08:25 PM
David,
did you check all of the pulleys to see if they spin freely?
This of course is done with the engine off, and the belt removed.
Old 01-26-2012, 08:43 PM
Also check to see if the crank pulley is separated. There is a rubber layer between the two metal layers. If you paint a line across the 3 layers, then run the car it will be real easy to see if they are staying together.
Old 01-26-2012, 11:50 PM
The NEWBIE
i'll tighten it more that last time to see how it goes...do i have to tighten it just to take the squeal away? how would i know if it's tight enough?
David,
i did that right after it came off...everything spinning pretty good!
changed the timing belt a few weeks ago and i checked the crank pulley too...seemed very solid actually...
What about the warning lights? can it be that the connector to the alt is messed up?! cuz i wrestled with it to take it out....freaking subaru connectors
DIY FTW!
Old 01-27-2012, 12:06 AM
immortal_suby's Avatar
Thread Killah
Could be that the new alternator is bad.
Locker Link
2015 BRZ Limited 6MT
Old 01-27-2012, 12:18 AM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
I have run into this issue a few times
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 01-27-2012, 12:23 AM
The NEWBIE
bad alt lights the warning lights up?!
what is the connector for? on is for + to battery...what is the other one for?
DIY FTW!
Old 01-27-2012, 12:44 AM
What is the connector for? one is for + to battery...what is the other one for?
On the plastic connector, one that plugs into the side of the alternator wire is the field sense wire, that energizes the alternator when the ignition is on. Also monitors battery voltage and uses the regulator to supply additional voltage on demand
The other wire goes to the idiot light on the dash, turning it off when the alternator is charging.
If you need a new plug, they can be ordered from Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070
The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum.They cone with 3-4" of wires already attached so you can splice.
Old 01-27-2012, 05:10 AM
Also look at the two smaller wires from the plug as they lead across the top of the alt and AC compressor. They get brittle and may have cracked.
Old 01-27-2012, 09:55 AM
jellybytes2 jellybytes2 is offline
soup IS good food
+1 for this I had to replace this connector when I replaced my alt a few weeks ago. After replacing the alt, the light we still coming on. One of the wires was badly frayed right at the connector. I called this place and I had the new connector in a couple of days.
'97 SVX 'Brilliant' Reddish
'94 SVX Lagina
'93 SVX Less Reddish
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 01-27-2012, 03:48 PM
The NEWBIE
so those are the reason for the dash lights...i actually did look up for the connector but couldn't find one
thanks...
they used to be fine even on the last alternator so i'm guessing the problem is from the connector...
how can i make sure that it's not short circuiting?
DIY FTW!
Old 01-27-2012, 06:42 PM
I had the problem once after I changed the alt. I think moving the wires during the alt swap cracked the insulation and caused a short. If the plug and wire at that end are brittle get the new plug and dissect the wiring shroud until the wires become flexible. This may be a good time to go ahead and do SVXcess's alt wiring upgrade.
Old 01-27-2012, 07:05 PM
I had the problem once after I changed the alt. I think moving the wires during the alt swap cracked the insulation and caused a short. If the plug and wire at that end are brittle get the new plug and dissect the wiring shroud until the wires become flexible. This may be a good time to go ahead and do svxcess's alternator wiring upgrade.
Which can be found HERE
Old 01-28-2012, 01:02 AM
The NEWBIE
SCXcess wiring looks great and the fuse is really useful but you barely added 0.2 volts which IMO is mostly from the alt...i don't think that it was worth it
so is it safe to drive on it with the warning lights on? at least until i receive the new plug?
DIY FTW!
