Old 10-01-2009, 09:52 AM
s'ko s'ko is offline
PCV replacement. Pull manifold or not to pull.
Ok so I read that post about the PCV replacement in the how to section.
Seems like it's a major PITA to get to. I am wondering if it will take the same amount to time to remove the top part of the manifold and remove the PCV that way.
Thoughts?
BW
Old 10-01-2009, 01:38 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: PCV replacement. Pull manifold or not to pull.
Use a crow foot wrench or make one up. Check my old locker for a photo of my wrench.
Old 10-01-2009, 01:57 PM
SomethingElse's Avatar
word words wording
Thoughts?
BW
Thoughts point to do not pull your manifold off. It is not required. It will not save you time...you will brake stuff....maybe
Eric
Old 10-01-2009, 04:21 PM
hi pull the hose off ,use a mirror and see if its glogged ,if its in good shape leave it alone ,you can change it with a bent wrench and some nimble fingers
Old 10-01-2009, 04:28 PM
many brittle and heat worn vacuum lines are quietly waiting for you to disturb there resting place and once disturbed oh how they will break and laugh! I would not pull the mani unless you needed to or wanted to do the thermo spacers. My .02
Old 10-01-2009, 04:39 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Yeah do the crows foot wrench thing, dont yank the manifold unless you have all of the needed gaskets for the intake, EGR, and throttle body and lots of vacuum line.
Old 10-01-2009, 04:42 PM
word words wording
and vacuum resivior box...I hate that thing!
Eric
Old 10-01-2009, 04:56 PM
immortal_suby's Avatar
Thread Killah
I would pull it and replace all those brittle lines that are leaking vacuum in the process. Preventative maintenance.
And be careful to not break any of the craptastic plastic fittings in the process.
Locker Link
2015 BRZ Limited 6MT
Old 10-01-2009, 05:01 PM
Just keep an eye out if you drop the old valve. Mine fell and now rests somewhere below the coolant cross-over. I'm sure I'll find it again someday.
Old 10-01-2009, 05:33 PM
touche'
if you are mechanically inclined enough, have the money for all the gaskets, and hoses, and take your time that is the best idea! However the easiest is just leave it as is and remove it from the top.
