Old 08-05-2009, 11:04 PM
robinhoodof she robinhoodof she is offline
PCV location
Where is the PCV valve located, have the oil dip stick pop'n up , need to check the ccv
Old 08-06-2009, 12:00 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: PCV location
Under the throttle body, rear of engine.
Old 08-06-2009, 12:05 AM
Re: PCV location
The How-to Documents link should always be your first stop.
Click HERE for the procedure with photos.
Old 08-07-2009, 12:50 PM
Re: PCV location
Thanks Guys!!!!
Old 08-07-2009, 03:41 PM
Re: PCV location
If that doesn't stop it, you can put a new O-Ring near the handle of the dip stick. That way it won't work its way out of the tube.
Old 08-07-2009, 07:56 PM
Re: PCV location
did that first due to the o-ring was flat and brittle
