Old 07-20-2006, 12:19 PM
craftylandshark craftylandshark is offline
tranny problem/no tcu code
i'm afraid my transmission is on its way out shifting into and out of second gear is happening WAY too late, and it feels like the clutch is working WAY too hard in that vicinity. no flare, just a late shift. i'm not getting anything from the TCU except the old code from when i unplugged the resistor to see if that helped (as expected, the shift firmed up, but it still came late - somewhere around 3500-4000 rpm under tame city acceleration). My ATF level is fine and the fluid is clean, but the diff fluid is thick, opaque brown and sludgy. (This could be how it's supposed to be, never dealt with diff fluid before, but i doubt it) I'll be draining and changing that later today.
It seems like 2nd is usually one of the first gears to go when our trannies are dying so am I likely looking at a rebuild? My mechanic reccomended a tranny guy - I'm gonna take it by his shop hopefully tomorrow and he's gonna look it over, but if there's a miracle cure for this (riiiiiiiight ), someone please tell me lol
Kevin Crutchfield
Neophyte SVXer
92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying
92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's
Old 07-20-2006, 02:34 PM
The first thing you should do is adjust your T.P.S.(throttle position sensor) to 0.50 volts with the key on, and everything else off.
Old 07-20-2006, 02:35 PM
seion seion is offline
Subaru Engineer Wanabe
Diff gear oil is yellow and thick when new; change yours now. Adjust your bands as well (do a search for band adjustment).
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 07-20-2006, 04:39 PM
Akirpach
Hi, I've got a 92 that is doing the same thing, but also will hunt up and down at steady speed and now sometimes it will start in third gear even if the manual button is pushed and stick is in low. fluid looks good and when acting normal - shifts nice. any suggestions ???? thanks
Old 07-20-2006, 05:37 PM
Starting in 3rd is indication of a malfunctioning (or missing) TCU.
Hunting at a steady speed is usually a bad/dirty signal from the TPS (Throttle Position Sensor)
Old 07-20-2006, 06:23 PM
Yes I agree with the old guy, .
If the trans is shifting at a higher speed than it should, it is because either, the TCU is seeing the throttle being open wider, than it is. Or it is seeing the road speed as being slower, than it is.
If it was seeing a slower signal from the speed sensor, it would be trying to lock up the Transfer clutch. If it saw both speed sensors as slow, the speedo would read slow also.
The Throttle Position sensor would be giving a higher than normal, voltage reading, as Tom says.
Old 07-20-2006, 06:58 PM
The Throttle Position sensor would be giving a higher than normal voltage reading, as Tom says.
Simply setting/checking the TPS voltage at idle will not locate a fault in the TPS potentiometer. This is arranged as a voltage divider and the voltage could go high at an intermediate position. Check the output voltage while moving the sensor through its complete range, if possible using an instrument with a bar graph. The delayed response of a normal meter may not show up a very short intermittent, but with care is still useful and wotrthwhile. The previous post describing a possible "dirty" signal is apt.
Old 07-20-2006, 09:42 PM
Thanks
Old 07-20-2006, 10:25 PM
Thanks
from Harvey for sure. Not to worry, I have kids older than you and get called much worse.
Old 07-20-2006, 11:03 PM
Well, it was Tom that was complaining about turning 50. Geezes if I was that old, I would still be racing bikes.
Old 07-20-2006, 11:35 PM
With engine I'd be on a push bike
Old 07-21-2006, 04:24 PM
thanks all! i changed the diff fluid from the sulfury pits ... from the looks and consistency of it god only knows how long ago it was changed. i read over and looked at the pics of the TPS and Brake Band adjustments and they're honestly beyond my capabilities right now. so the tranny shop has the car, and i passed the information onto them. Trevor - are they likely to know how properly to check the TPS re: your post?
Kevin Crutchfield
Neophyte SVXer
Old 07-21-2006, 04:26 PM
BTW, has anybody made the Office Space TPS Reports joke yet?
Kevin Crutchfield
Neophyte SVXer
Old 07-23-2006, 02:58 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
yeah, in case you didn't get that Memo......we're putting cover sheets on ALL of the TPS reports now......
Did the diff change fix the problem? I did change the diff fluid once.....guess I kind of forgot to change it again.......sorry
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 07-23-2006, 05:31 PM
[QUOTE=
Trevor - are they likely to know how properly to check the TPS re: your post? [/QUOTE]
I doubt that they would try. The rule is usually, if its faulty or even suspect, fit a new one and charge the customer. Less hassle and more profitable.
What is more, within all trades these days, there are two defined levels of qualification. There are few considered as being at "component level", i.e. who know what is going on inside each black box and can repair the inner components. Check the ads covering employment where this term is often used.
Sad but true and hence the advantages of in many instances, doing it yourself. Also check the how to section, for more detailed advice.
