Old 01-23-2005, 04:18 PM
92black svx
impreza tranny
what all do i have to pull from a impreza to make the trans work will it bolt right to my engine
Old 01-23-2005, 05:34 PM
You have only the transmission to pull from the Impreza.....
You have to use the svx tcu.
You can not use an Impreza rear end, unless it is a five bolt side plate rear end.
You HAVE to use a torque converter from the svx, or from an Legacy Outback with a 2.5 engine.
You have to re-use the speed sensor from the svx.
You have to use either a 4.11(matching the trans ratio) limited slip or use the Legacy housing with the svx limited slip carrier, mounted in the Legacy five bolt side plate rear end.
Old 01-23-2005, 05:49 PM
lee lee is offline
What svxfiles said ^^^^
I had to use the input shaft from the SVX in a 98 model Imprezza transmission as the end of the Imprezza shaft stuck out further than the SVX shaft & wouldn't allow the torque converter to fully seat - it's an easy swap, slide one out, slip the other in.
