Old 08-16-2009, 07:19 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
So your SVX won't start??
Before you spend an hour at night with a failing flashlight to undo the top of the driver side timing cover, and disconnect the O2 sensors, and check for codes, and disconnect the fuel line to check for fuel, and pull a coil and plug to check for spark, and swap a MAF off of your Legacy, and get it towed at 11:00 at night an hour to your house, and then on your next weekend off pull the radiator out and the whole front end apart to find the timing belt is dead on, then have a friend drive two hours out of his way on a 90* day with no air conditioning in their truck, check one thing...
Make sure that the connector didn't become disconnected from the TPS sensor...
Old 08-16-2009, 07:47 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: So your SVX won't start??
Holy Sh*&...really? Sorry to hear of your troubles. Maybe we should start a fail to start checklist...LOL
1995 Subaru Svx L / AWD
Old 08-16-2009, 08:02 PM
michael's Avatar
michael michael is offline
What Potholes ???
How did you find out it was that? Visually? I just adjusted mine today, I'm going to double check my plug now!
Wanted: Steering Wheel
Old 08-16-2009, 11:09 PM
teeheeheehee, SNORT!
Old 08-17-2009, 01:13 AM
subiemech85 subiemech85 is offline
engine die and no re-start? air tube AFTER MAF disconnected
everything fine when shut off now power gone when turning key to start... bad mains connections, unless slamming the door cures it, then it's loose fuse link :banghead:
very touchy throttle... air filter plugged
loss of performance after prolonged driving in near freezing rain, sleet, snow ... water soaked AIR filter
runs good for short while then loss of power, repeat ... plugged fuel filter
died while idling, no restart ... sripped dist. drive gear due to siezed shaft
not quite right, slightly rougher idle and not as much power ... valve adjustment, if persistent ... bent pushtube
gas leaking into cabin ... return hose loose allowing leak after completely filling tank and parking in heated garage
excessive fuel consumption or hard start or black smoke ... choke not working
backfiring after installing new cap ... wrong markings on cap
clutch pedal floppy or stuck to floor ... excessively loose adjustment
fuses blow, windows, turn signals, 4x4, cruise control ,etc. don't work ... clean ALL grounds
mysterious impossible to find coolant leak ... hose rubbed by clutch lever
oil pressure light always on after starting ... gauge type sending unit used to replace switch
volt meter goes to 18 ... no battery connection
engine overheating ... radio fuse blown
no spark ... fuel pump fuse blown
volt meter not above 12 ... alt plug disconnected
1 qt oil loss / tank of fuel ... loose oil pan and valve covers
oil pressure goes down on corners ... VERY low oil
dead battery ... forgot you weren't driving a gen2 or newer subaru and left the lights on
won't run below 2k ... dying ignition module
won't start or dies after warming up ... dying ignition module
very picky about every detail of your car ... typical SVX owner
some of these may be slightly off topic, but are all true and happened to me, and are good to keep in mind
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic
click here for fuelly mpg info
Old 08-20-2009, 05:51 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
...then have a friend drive two hours out of his way on a 90* day with no air conditioning in their truck...
But they're such GOOD friends
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
Old 08-20-2009, 05:56 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
...that Dave didn't even think of offering one of his WWII rationed cans of beer to for putting an electrical connector together.
