Old 04-05-2005, 01:27 PM
lurker lurker is offline
Replacing an Engine
When you put a new motor in your SVX do you usually have to tinker w/ the timing chain?
Old 04-05-2005, 01:29 PM
svxpert svxpert is offline
<<When you put a new motor in your SVX do you usually have to tinker w/ the timing chain?>>
I hope not. I HATE working with chains. I'd much rather work with belts.
Old 04-05-2005, 01:36 PM
Oops I meant belts.
SVX's have an overhead cam too right?
The problem is , I had a used engine (30,000 miles) installed in the SVX. The engine had a 3 month waranty. My mechanic got some parts off of my old engine (without my permission which voided the waranty) and put it in the new engine. No less than a month , car won't steer and he says that the timing belt could be busted and that the engine could be gone as well caused by the timing belt.
After spending spending $2500 on the svx, he wants my permission to look at the car or whether I decide to buy a new car? WTH?
Old 04-05-2005, 02:07 PM
Originally Posted by lurker
Oops I meant belts.
You need a real mechanic!
First of all they have a single timing belt that turns the two bottom, or exhaust camshafts. They are geared to the top (two) intake cams.
The engine has four cams, two over each head.
IT IS A NON-INTERFERENCE ENGINE!!!
That means if the camshaft belt breaks, the engine quits, stops running , but the valves cannot hit the pistons.
If the engine runs, but the power steering is not working, MAYBE it's just a broken or loose power steering belt.
Or the crankshaft pulley separated from the hub,
or it lost power steering because the automatic transmission fluid,used by Subaru in the svx, has sprung a leak, or is old and worn out.
If the engine does not run, then it is another story.
I would take it to a Subaru garage, or get a mechanic you trust to look at it.
We need more information. Tom
Old 04-05-2005, 02:22 PM
I would gladly take it to a mechanic who knows what they're doing. Problem is, there isn't that much here in Upstate NY. He comes very highly recommended by subaru owners but he did admit it was his first time to work on an svx.
I love the SVX and actually spent $4000 on it since I owned it. It's can be a head ache though if I don't find a mecahnic who knows what they're doing.
Thanks for the responses and I will get to the bottom of this and ask for more info.
Old 04-05-2005, 02:42 PM
I would at least find a mechanic who has worked on an SVX. This guy doesn't sound like he will do the best job for you.
Old 04-05-2005, 03:17 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Just curious but why do you need a new motor? Unless it had catastrophic failure due to lack of oil these engines are pretty much bullet proof. As for your question it isn't that hard to put the engine in provided you have the right tools to do so (i.e. engine lift, etc) if you don't then taking it somewhere would probably be wise esp if you don't have 3 friends willing to help who have engine removal/ install knowledge... No you won't have to touch the belt so long as you don't replace it in the engine going it (which I would recommend you do that, the water pump and replace all the gaskets before installing). You'll pay more later if you don't.
Old 04-05-2005, 04:01 PM
immortal_suby's Avatar
Thread Killah
Have it towed to VanBortel subaru on rt 96 in Victor. They will fix it right. Their service department is great.
Locker Link
2015 BRZ Limited 6MT
Old 04-05-2005, 04:53 PM
does the engine run? If it does, you simply have a PS problem. Now that I think about it, the JA mech you are using now might have dropped the ball and bent the crap out of your hard lines on the rack when transplanting. I am not sure as I cannot see it myself but if the engine runs, it is probly just a dumb PS problem.
Old 04-05-2005, 11:59 PM
Originally Posted by tomssvx
the JA mech you are using now might have dropped the ball Tom
Sorry, but it ticks me off when "professionals" don't bother to research but still claim/profess/express prowess!
Old 04-06-2005, 09:19 AM
blacknite blacknite is offline
Sometimes Mechanics Are Like Doctor. They Just Give You Something
To Slow Down The Problem But Not To Correct It Right Away, Ask Electrophil About It!!!!!!. That Way They Can Keep Digging In Your Packet To Reach For Your Money.... But Exactly What Is Your Engine Is Doing Or Not Doing??????
Old 04-06-2005, 09:21 AM
Doesw The Car Has A Hard Time Going Up Hill??? Or Do You Have Lack Of Power????? Is It Heating Up????? Rpm Are High While At Idle???
Old 04-11-2005, 09:16 AM
According to the mech, the harmonic balance of the engine broke which then screwed up the timing cover.
If so, anyone know the ball park cost to have these problems fixed?
Old 04-11-2005, 09:27 AM
Mr. Pockets's Avatar
Moderator
It's not actually a 'harmonic balancer.' It's just a 'crank pulley.'
http://tinyurl.com/5hxzn
Item #2.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-11-2005, 09:29 AM
Item #2.
are you certain about this ?
