Old 03-06-2006, 07:22 PM
spinn360's Avatar
spinn360 spinn360 is offline
tps at 1.5 wont go 0.5
So I tried to set the TPS and on the voltometer it says 1.50 and ranges from 1.4ish to 1.8ish but nowhere near 0.5v. My car runs like crap full throttle at half throttle bogging at full throttle. I replaced the TPS still doing it dont know what to do. Also the code for both o2 sensors was thrown I cleared code and drove around for 30 min and no code even though it ran like crap binding kindof thunk from rear when taking off and turning at the same time. Please someone who knows how to fix this hell car please let me know. I am about to lose all faith in anything subaru.(especially the SVX)
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 03-06-2006, 08:56 PM
Are you tapped into the white wire?
Are you doing the testing with the ignition on, at closed throttle?
Old 03-07-2006, 03:50 PM
spinn360's Avatar
I think its all right
I tapped into white wire in middle with ground on neg of battery and the car was at idle is it supposed to be off with ign turned on but car not running??
Old 03-07-2006, 03:56 PM
dwd1985 dwd1985 is offline
Sounds like we found the problem. Dont connect the negative on the voltmeter to the battery negative. Instead, connect it to a neutral ground, like maybe the metal bar that holds the battery in place. I bet this will fix your problem.
Old 03-07-2006, 04:03 PM
spinn360's Avatar
so it is supposed to be at idle when testing??? Because thats what I was thinking I did wrong. I always misread the instructions arrgh
Old 03-07-2006, 04:27 PM
dont worry, I just adjusted my TPS, and the instructions for it totally suck, so I had to ask to. The proper way the instructions should be read should be
1: Stick the pin through the white wire.
2:connect the positive lead to the pin
3: connect the negative pin to a neutral ground in the car
4: Start the car and let it idle
5: turn the TPS until it is at .5 volts.
Old 03-07-2006, 04:29 PM
spinn360's Avatar
Ok I will try it again with the ground on a nuetral ground in car not on batt post
Old 03-07-2006, 05:13 PM
I havent looked at the how to or anything but if you are actually using a pin on the wire and puncture the shielding i would definitely put some silicone on the puncture and then tape it really well. I would try to backprobe the wires you need for the tps with the same pin. Thats how i set mine and also it was with the KOEO(key on engine off) You always want to try and avoid pucturing wires. Take it for what its worth. Thats how i was taught.
Old 03-07-2006, 05:25 PM
spinn360's Avatar
well I tried with the KOEO and only could get it down to .72 or so still no .5 I tried on and off the battery post and every other ground and same thing. I will trie running it at that and see but I have little faith in my entire car.
Old 03-07-2006, 05:46 PM
I would definetly start the car. That is what it says in the how-to, and that is what I did too, and it went to .5 Volts immediately. Try it that way, it will work.
Old 03-07-2006, 07:40 PM
spinn360's Avatar
I dont think you understand DWD I tried it that way first then I tried it with out it started and it was a little better not started but still not at .5v I mean all the way to one side it couldnt turn any further was .72
Old 03-07-2006, 07:53 PM
TPS setting.
The setting is done, Throttle closed, Ignition On only, don't start the engine. As you are measuring the sensors voltage, measure it at the sensor. Positive on the white wire, Negative on the metal part of the sensors body. Specs are 0.45V to 0.55V.
Old 03-07-2006, 08:09 PM
sorry, I didnt think you had tried it that way yet. I thought after I told you about the negative to ground thing that you had tried that, but with the engine off. But apparently, according to Harvey, it is supposed to be off. Now im really confused.
Old 03-07-2006, 08:16 PM
Yes that is taken from the Bible. The difference in the measured voltage is from all the ground connections, between the sensor and the battery.
Old 03-07-2006, 09:21 PM
AND, there should be little to no differance with the engine at idle, or with the key on, and engine off.
