Old 08-07-2008, 12:42 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Disc pads & Rotors - world compatible?
I have just had my car serviced (pick-up later today) & the guys reckon that in approx 3 months the pads will be down to minimum, they also mentioned that the rotors are pretty thin also.
So I was wanting to "upgrade" both front & rear to drilled & slotted rotors together with ceramic pads.
But my question is are these parts the same around the world?
I will find out the part numbers from New Zealand.
Does anyone know if Dayle still works at www.Motorsportwarehouse.com as I am keen to buy from them (as I have bought stuff from them before).
thanks
Stephen.
Old 08-07-2008, 01:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Disc pads & Rotors - world compatible?
OT has a nice brake/rotor/stainless steel brake line kit at a good price
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-07-2008, 01:41 PM
Re: Pads & Rotors - world compatible?
thanks
Stephen.
Dayle is still at Motorsports.
I believe that your rear rotors are different from what we have in The States.
Are your rear rotors ventelated?
Old 08-07-2008, 01:42 PM
SURTEESS's Avatar
what / where is OT ?
Old 08-10-2008, 03:48 PM
SURTEESS's Avatar
Cool Re: Pads & Rotors - world compatible?
Mine rears are solid, but would consider changing them to vented - if I knew that they would fit?
Old 08-10-2008, 04:07 PM
That would be me.
It stands for Old Tom.
Old 08-10-2008, 04:18 PM
If your rear rotors are a solid, and no less tham 8.5 mm thick, and just over 11" in diameter with drum parking brakes, then you can use the rotors that we use.
Switching to thicker rear rotors would require different rear calipers.
Old 08-10-2008, 06:07 PM
SURTEESS's Avatar
Yes Dale has already outlined the different thicknesses between solid & vented - so will have to stick to solid ones.
Old 08-31-2008, 10:49 PM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Give me a ring, I know a place in NZ that you can get the work done - also I have a set of slotted rotors that will suit you. 07 3773465
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 09-01-2008, 05:34 AM
legacyau legacyau is offline
Just to hijack this thread does anyone have the pad part numbers for the svx in yankee land ?
