Old 04-21-2008, 07:31 PM
Speedklix's Avatar
Locker Link Solution
Originally Posted by black beast View Post
brembos dont fit? Really? I could have sworn someone on here was selling the braket adapter...
even if you have a bracket and custom rotors, our mounts are further out from the center of rotation, I believe it was determined that you would need a larger wheel.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 04-21-2008, 07:39 PM
The problem is that although the calipers will bolt on, they will be farther out than on an STi, which means we would need custom rotors with a bigger diameter. This is all do-able, if you have the money to throw at it. The reason it can't be done is that the STi caliper is meant for a rotor no bigger than the STi's. Trying to mount the caliper over a huge rotor would mean the caliper would either touch the rotor at the top and bottom, or areas of the pads would not be touching the rotor. Either means it's a no go.
Old 04-22-2008, 09:16 AM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
o, thanks for the info...
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 04-22-2008, 11:55 AM
wawazat??'s Avatar
Yeah, I'm still around
Originally Posted by Crazy_pilot View Post
Powdercoating does not make the wheel any weaker. One of the local club guys races an STi with those wheels, powdercoated, as his dedicated track wheels and they haven't had a problem after 2 years.
Powdercoat does not weaken the wheels, but the 400F process temps typically used to flow the polyester powder do change the temper of the forged aluminum used b BBS on these wheels making them more flexible (reducing the modulus).
Down to none
Old 04-22-2008, 06:06 PM
Speedklix's Avatar
wow, it is that drastic?
makes sense when you consider the circ. after extending the rad just an inch... so who needs to unload some brembos cheap???
-Mike
[SIGPIC][/SIGPIC]
Old 04-22-2008, 10:31 PM
you do realize he said it is not a possibility right?? I did all the measurements, they will not work... even with a larger diameter disc
