17" Rim Upgrade Success Stories - PLEASE POST HERE
Hi,
I recently got new 17" rims. The wheel/tire setup was balanced and tested on the Hunter GSP9700 equipment twice and I can't get vibrations to go away at speeds above 60mph - the tires check out so I am beginning to suspect the quality of the rims. Any members who have successfully upgraded to a 17" setup and have a smooth ride, please post your rims' brand and model number here so I can shop around again. The car drove like a dream with the stock wheels and I have around $450 invested in a great set of 17" Pirelli Nero tires so I really need some wheels that will work. Thanks!! Todd |
17x7.5" x 48 mm offset Rota Subzeros. Inexpensive, light, and strong. I've gone 110+ mph many many times without a problem. I'll probably upgrade to 17x8 Torque or Boost this summer when my current tires wear out down to the cords. :-)
http://www.rotawheel.com/ Check out the "Stock Check" link to see the sizes that are available for each design.
Forged 17X7.5 Loco's, through Dayle at Motorsports Wharehouse, w/225/45/17 Hankooks. Balanced at Red Hill in Cumberland, no vibration up to 110 or so.
Closed course, professional driver. They might need to check their machine, or they might not have set it up properly for your offset, or wheel diameter. The best equipement is only as good as the person who uses it.
Check that the rims are not out of round.
Check that your suspension is not loose (ball joints, etc...). Ensure the rims are properly (evenly) torqued.
And make sure that the lug nuts are good quality and are the correct style for those rims.
-Bill (always looking to improve the state of SVX as he knows it )
...and I'm sure they'll look 'killer' on your Laguna Blue SVX!!! -Chike
wheel problem
Tooth,
Are your new wheels hub-centric or lug-centric? I understand(never experiencd this), that if the i.d. of the wheel isn't a "snug" fit on the cars' hub(hub-centric), then the lug nuts are all that "centers" the wheel when you torque them(lug-centric). Perhaps measure the inner bore of the wheel, compare that to the hubs diameter. I don't know the hub dimension, but I'm sure someone here does! That might be your problem. Good luck. mile-hi-bri |
18 X 8 ALT Rims from Dayle at MotorSport.
225 / 40 P Zero Nero tyres. No worries up to 120+ Also have a set of Arelli 17" rims for sale with Kumho tyres. Hope this helps. Jonathan
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf. |
I have 18" Alessio Turbo rims with 225 40's . Balance is great at 100 plus but the offset is a little to much ,on cornering or shopping store speed bumps the do rub a tiny bit on inner rear wheel moulding I bought them from Discounted Wheel Warehouse, They offer free shipping on any wheel package. They located here in California, but the free shipping is good for all US
I have 17' with 245 45 17 tires 120 no problem i post pic aometime back but think there are in my locker
Thanks for all of the replies. Does anyone have any experience or know someone who has Motegi wheels?
-Aaron SVX: '92 Dark Teal 101k '97 Legacy GT Wagon: dead '99 Civic Si: daily driver... stolen and stripped with all my tools! '92 Yamaha FZR 600: garage 2011 Jetta: Daily disappointment |
Rota Boost 17x8 Bronze
Just had these mounted last week for my buggy. As noted below using 245/40-17 BFG g-Force T/A KDW-2 tires. Used black Muteki open end lugs. Fit perfectly. Tire wheel combination has crisper response than stock wheels with 225/50-16 Pirelli P Zero Neros. No rubbing even over Princeton's notorious potholes. Pictures below
[IMG=http://www.subaru-svx.net/photos/files/shotgunslade/26522s.JPG] If the above image line doesn't show up as a picture, can someone tell me what I did wrong? Thanks
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
