Old 01-22-2005, 11:41 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
Lights?
Highs are 9005
Lows are 9006
Fogs are 9006or 9005
these are correct right?
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 01-22-2005, 02:17 PM
Red Wolf's Avatar
Red Wolf Red Wolf is offline
On The Road Again...
Send a message via AIM to Red Wolf
Lightbulb Fog Lights
The fog lights are H3's at 35 watts, if I remember correctly.
- John
1996 Subaru SVX LSi - "Red Wolf" - In Storage
2001 Subaru Outback L.L. Bean Edition - "Angel" - Mom's
2006 Acura RSX - "Grey Wolf" - Current Daily Driver
Old 01-22-2005, 03:44 PM
curly2k3's Avatar
Own'eded
thanks,
Old 01-22-2005, 03:49 PM
Speedklix's Avatar
Locker Link Solution
fogs are H3
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 01-22-2005, 06:08 PM
Rob
I'm not attempting to hijack, however along this topic does anyone have a shortcut/tip for replacing the foglamps? Either my hands are too big or I am missing something.
Old 01-22-2005, 06:18 PM
Speedklix's Avatar
if I remember correctly, you have to turn the cover. The tab on top is a good place to slip your finger behind to pop the cover off once you have turned it.
Then remove the connector that attaches to the wire. (you'll see when you get it open)
Then there is like a spring clip that holds in the bulb that you squeeze off.
Be careful not to touch the bulb with your fingers. The oil in your skin isn't good for bulbs when they get hot.
If you're having a hard time with the clip that hold the bulb, try some needlenose pliers.
-Mike
[SIGPIC][/SIGPIC]
Old 01-22-2005, 07:34 PM
n00b on demand's Avatar
Fog light replacement is so annoying. Just remember to do it when the engine is cool otherwise the radiator will burn the **** out of your hand.
Old 01-23-2005, 01:06 PM
curly2k3's Avatar
Own'eded
danke, got the highs and lows, but no H3's in stock so, they'll have to wait for another day.
So much is new now, new axle, highs, lows, ceramic pads, all sorts of junk, I might even get slotted rotors and some new rims, and probably a new oil change tomarrow.
Old 01-23-2005, 02:45 PM
curly2k3's Avatar
Own'eded
BTW, what is the standard size rim of the SVX?
Old 01-23-2005, 03:15 PM
AFBeefcake's Avatar
Subaru Swapper
16 X 7 with 225/50/16 tires
55mm offset
5 x 4.5 bolt
2005 Legacy GT
My WRX's Cardomain Page
Old 01-23-2005, 05:20 PM
curly2k3's Avatar
Own'eded
thanks.
Old 01-23-2005, 05:41 PM
Originally posted by AFBeefcake
16 X 7.5 with 225/50/16 tires
55mm offset
5 x 4.5 bolt
Fixed your post.
Old 01-23-2005, 05:56 PM
curly2k3's Avatar
Own'eded
Old 01-24-2005, 12:46 AM
Originally posted by curly2k3
16x7.5
Old 01-24-2005, 03:35 PM
Green1995SVX
I always just remove the whole headlight assembly when replacing the fog lamp bulbs. I guess my hands are too big, but I just couldnt do it when I tried it with the headlight mounted to the car.
Mike
