Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 10-03-2016, 11:22 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: Manual transmission causes crankshaft wear!
What e-Mails?!
kyleerocket@yahoo.com
I re-sent my last email to that address. Did you not get it?
Tony
Old 10-04-2016, 09:41 AM
You say Heavy clutch pressure. What clutch is causing the problem? Looking at the main bearings in this engine does not seem possible that it would distort. How many so far have had the problem and what are the symptoms?
Old 10-04-2016, 04:00 PM
I have only seen one engine with excessive end play, or crankshaft walk.
But when I called an Subaru Expert, he already knew that this was happening. He stated that the wear on the crankshaft journal was dependent on whether it was a push or pull clutch system.
The evidence on my (or more correctly, now mine) crankshaft and thrust bearing followed his theory and experience.
As to what clutch is causing the problem, it is not brand related as far as I know, (but "We" only use about three different brands) it is more of a the higher clamping pressure, the more damage as collateral damage.
So far the best thing to do is to start the engine in neutral!
Only start the engine after oil pressure is built
I am looking into this but there is a lot going on and will report back as soon as humanly possible.
Old 10-04-2016, 06:29 PM
How do you wait for oil pressure to build with out starting the motor. Do we have electric oil pump?
Old 10-05-2016, 11:26 AM
I wish!
On my only 5 speed, (The Racer) I put it in neutral with the ignition and fuel pump switches turned off, and without pushing the clutch, I spin the engine for about a minute, (best guess) to get the oil pumping, with this 140k mostly stock (temporary) engine, (until I can install the new engine with the Eagle rods and the CP pistons) and after a minute, click on the ignition and fuel pump. It starts and instantly goes up to 80 psi, until it warms up.
By the time I install the new engine I will have it figured out. I hope.
Old 10-12-2016, 07:56 AM
I wish!
You have mail again.....
Tony
Old 10-13-2016, 09:08 PM
Hi Tony.
I just got back from a computer-less three day trip to install a water heater at my parents house in Pittsburgh.
Yes, THREE DAYS to install an instant on gas water heater replacing the thirty old one that was INCORRECTLY installed. I think by the well known Rube Goldberg!
Six.5 hours of travel time, 40 hours of waterboard-eske Home Depot shopping in two nearby cities, one run into a c8urb blowing out my 17" tire on The Claret, three days on ONE SHOWER!!! Four visits to tire and part stores. I'm home now. I will just sit here in the fetal position, rocking, humming to my self, maybe covering up with a blankey...
BTW Thank you Brian for the loan of your spare SVX tire, I got home fine!
Tony, now, after my rant, I'll go read the E-Mails that you sent.
PS. How do you spell "blankie?"
Old 10-14-2016, 10:39 PM
SVXBart SVXBart is offline
Liar !!!
Bart
Snort !!!
Bart
Old 10-14-2016, 10:40 PM
We all know that in reality it only took you 2 days.
Bart
Old 10-15-2016, 08:08 AM
Went up early (for me) AND left the house about 10:08 on Tuesday, and after stopping at the bank for like 40 minutes, got there at 2:30, still Tuesday, water heater crap,Home Depot, parents, Home Depot, parents, Home fkn Depot, blown lf tire, Jose & Tony's, stayed at Nick's place, Wednesday Advance the the good folks at RNR in Monroeville, then another Advance, water heater stuff, met with Brian, tire stuff, more water heater stuff, after 8:20PM(!) Jose & Tony's, Nicks place again
Thursday, drove back home in the fkn rain in The Claret, stuffed with tools, a blown tire, two big dogs, got home Thursday at 12:20 HENCE THREE DAYS!
Tuesday, Wednesday and Thursday, three days ya big Vodke swillin Jagoff!
Old 10-15-2016, 10:38 AM
shotgunslade's Avatar
Haven't been here for a while, but just saw this thread. i have some information about this issue which severely affected the first engine on my 94 emerald pearl. Engine was only slightly modified, Lan chip, exhaust camshaft substituted for intake camshaft, Snorkus. It had a 2004 WRX 5-speed, with ACT clutch kit and heavy duty pressure plate. By the end of its life, maybe 20,000 miles and 25 track days, with the 5-speed, and 105,000 miles overall, it had serious thrust bearing wear. To the extent that I was routinely throwing belts, and even had the timing belt slip a tooth. Young Tom can vouch for this. He autopsied the engine, after it fried as a result of a burst coolant connector hose across the top of the block.
Of course, later, with a new block and crankshaft, he built the famous 246 WHP NA engine, along with other mods that ultimately made it car of the week on Bringatrailer and got it featured in the Drive Channel weekly chat show. With that engine, on his advice, I always started it in neutral, and, and at stop lights put it into neutral, totally minimizing the time with the clutch pedal down. My experience is that this is really a thing.
Old 10-15-2016, 10:52 AM
Thank you Dan.
Old 11-14-2016, 10:21 AM
There are two switches on the trans. One is the reverse switch which we all use for reverse lights. The second is a neutral indicator for cruise control. It is open in neutral and closed in gear. You must use a relay wired to the 87a terminal to reverse this in order to act as a neutral safety for the starting circuit. Or just hardwire the circuit. Either way you lose cruise control.
Old 11-14-2016, 10:25 AM
Hi YT. Its been a rough week!
