Old 03-18-2012, 08:55 PM
dbarnblatt's Avatar
Re: One other question.....Struts
Yes. Koni has stopped making their inserts. Also, the new struts from subaru are close to worthless. Subaru has not stored them properly and they typically don't last longer than a year. There are basically no viable strut options for our cars anymore.
I installed Konis a few years ago and the rears needed to be reseated in the top hats a few times because the piston (?) rod that fits into the tops were rattling around badly. They seem to be machined too narrow for the hole that they slide though in the top hat mounts. There is also another small little disc that fits just under the mounts that rattles around. The whole thing is driving me crazy!
Also, I've noticed that one front strut has been leaking what looks like oil as it is splattering on the black plastic trim piece that covers the strut mount.
I'm taking the car back in to have the rears looked at again.
If that doesn't work I'm tempted to buy a set of new Subaru struts as there is a recent manufacturing run and they should be fine.
Old 03-18-2012, 08:58 PM
Has anyone noticed that (for the front gc springs) the metal hat that sits on top of the spring destroys the bearing in the strut mount? I was installing bumpstops a few weeks ago and that metal piece really tears into the strut mount. I'll try to get a pic soon...
Old 03-18-2012, 09:18 PM
Green1995SVX's Avatar
Originally Posted by Huskymaniac View Post
If a new batch was made in 2008, where did they store them that was so bad that they are only good for a year of use? Alaska?
Unfortunately I don't have that information. People on the forum have speculated that it is from the struts being stored on their side, causing the seals to dry out. This was a problem that was occurring even 10 years ago when I worked in the parts department at a Subaru dealer. We were replacing struts under warranty even after only a few months because the seals blow out. This is not something a few people have made up. This is a real issue with the OEM struts - especially the rears.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-18-2012, 10:07 PM
dbarnblatt's Avatar
I know, I've heard the issues. Was it happening with other Subarus models besides the SVX when you were there?
It's weird because Subaru struts are no different than other brands and manufacturers. Do parts suppliers have a specific way to store struts?
Old 03-19-2012, 02:02 AM
Old Fogey
David, your Konis have lifetime warranties. Take some pics of the leak and contact their service department. I think I worked with a guy "Stoney Hamilton iirc". They should charge you half retail for the replacement, but refund that to you after return of the failing strut and verification by them of the failure. I replaced a front strut a few years back , on them. So sorry to hear of your continued frustration with the rears in your car. I wish I knew what else we might have tried to fix that rattle.
Glenn
Old 03-19-2012, 10:34 AM
Gamesy's Avatar
Gamesy Gamesy is offline
does anyone have the dimensions of the konis?
Old 03-19-2012, 10:47 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I want a kit for Crazy Pilots suspension
Old 03-19-2012, 11:14 AM
lol! That would be quite the thing to put together.
Knuckles, control arms, coilover top mounts, lower mounts, swaybar links... Plus the coilovers themselves.
There is always a chance that Stance would be able to make a kit for the SVX. It wouldn't take a huge amount of work for them to adapt a WRX/STi system.
Old 03-19-2012, 12:28 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Now one of my struts is making the "clunk" noise over any dip.
Old 03-19-2012, 12:56 PM
So I just emailed Stance, the maker of my coilovers, to ask if they would consider developping a system for the SVX based off the WRX one they already sell. Obviously they will look at it from a business perspective, but hopefully they'll be open to the idea. The bits needed to fit the SVX aren't much, just a machined aluminum camber plate and the lower mount. I'll report back if/when I get an answer.
Old 03-19-2012, 01:11 PM
Thank you sir. I already have Koni/GCs but I've never actually been able to drive the car since I've owned it to find out if they are worth a darn or not. I was told they needed to revalved when I bought the car. Wasn't aware til today they were so hard to replace.
Old 03-19-2012, 02:39 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Just one??
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-19-2012, 03:03 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
still no word from Nate on those ebay ones?
Jared
1992 dark teal SVX LS
Old 03-19-2012, 05:51 PM
Chuckls's Avatar
Designated Asshole
Originally Posted by SVX8588 View Post
Just one??
Yeah. :/
Old 03-19-2012, 06:24 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
It's a tale worthy of a Norwegian Saga at the moment:
http://www.subaru-svx.net/forum/showthread.php?t=58974
