#31
Re: Vexine: 1992 SVX
i used fiberall and fiberglass to fix the holes. i will later paint under the plastic with Rusolium paint. i still weld at times, this time i chose not to. |
#32
I just checked the video tour of your SVX VERY NICE I wish I saw it before you bought it I would not have made any neg comments. The hip in the windshield , can it be repaired? The antenna is it stuck or just doesn't go all the way down? The sun roof is the same on both the SVX I have owned (lazy to open). The 94 is a little better , it doesn't always need the little push.Thr roof is in real great shape, most have faded. The motor sounds strong and so does the tranny.Nice smooth idle. Quiet exhaust..Side glass almost perfect no scratches. Seats have normal wear.Fix the rust and touch up the other areas and you got a nice looking and running SVx you done good
#33
vexine failed inspection due to 3 minor things
1. Front Sway Bar Links 2. Right Rear Tire (can temporary fix no $) 3. Exhaust pipe on drivers side needs extended (can fix no $) Last edited by SubaruJawn; 12-13-2011 at 10:18 AM. |
#34
Cheapest front endlinks I have found: http://www.ebay.com/itm/2-FRONT-SWAY...item3a6042331d
#35
couldnt i just replace the rubber on them ?
#36
You could just replace the boot if there's no play in the link itself, but I don't know where you'd source them.
#37
#38
I would just replace them altogether.
#39
if its for the best, i'll go that route.
the link you gave me is for both left and right ? Last edited by SubaruJawn; 12-13-2011 at 10:59 AM. |
#40
Yea, the pair.
#41
Always something.... RATS. will that mean a front end or 4 wheel alignment? I find it strange that u needed it inspected. In CT only if it is an out of state car does it need to be inspected .
#42
PA has STRICT yearly inspections
#43
No cost tire problem what was wrong?
No cost Exhaust pipe what was wrong. |
#44
his tip is missing so it exits under the car before the bumper cover. easy fix.
as for the tire I'm sure he will come up with one and put it on. No biggie there either Sorry I didn't say anything about the exhaust John...I have a PA inspection License and I should have pointed that out to you. my bad.
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
#45
nope, it is just endlinks. that is an easy fix too.
