Old 11-22-2011, 04:06 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
automotive dehumidifier
does anyone know where i can buy one?
i have been looking for one for the SVX because i dont like my windows fogging up all the time but i am having no luck
Jared
1992 dark teal SVX LS
Old 11-22-2011, 04:20 PM
Re: automotive dehumidifier
Does your defroster not work?
Old 11-22-2011, 04:25 PM
it works...but it doesn't get all the windows and part of the rear windshield's defrost doesn't work.
this seems to be the best thing i can find....
http://www.eva-dry.com/products/
Jared
Old 11-22-2011, 07:35 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Try Google
1995 POLO LSI 76K MILES SOLD
Old 11-22-2011, 08:25 PM
Maybe you can repair it. Anybody ever tried these products?
http://www.frostfighter.com/index.htm
Old 11-22-2011, 10:10 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
I am puzzled...
If your Air Conditioning is working correctly, you should not get foggy windows. I am getting mine serviced tomorrow, but today it's raining and the rear windows etc fog up.
Just use your A/C and it will keep the air in the car nice and dry.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 11-22-2011, 11:53 PM
Originally Posted by BRADY View Post
I am puzzled...
This. + "recirculate" button. An A/C system is a dehumidifier. Having it recirculate means that it's re-dehumidifying the same air over and over.
Also, Sean, really good find on the frostfighter site. Lots of useful stuff.
Old 11-23-2011, 09:04 AM
I am puzzled...
the A/C DOESN'T work and i live in IL so i don't really need it for 8 months of the year...plus there are other things that need to be fixed...this is only like $25 that is why i was looking into it
Jared
Old 11-23-2011, 09:05 AM
thanks i will keep those in mind!
Jared
Old 11-24-2011, 08:00 AM
you can get your ac to work cheaply.
suck it out with $38 gauge set
http://www.harborfreight.com/a-c-man...set-92649.html
using $20 pump
http://www.harborfreight.com/catalog...rd=vacuum+pump
retrofit kit $13
http://www.autozone.com/autozone/acc...er=142674_0_0_
add couple cans of r134a w/ oil and sealer for 10 bucks a piece and your ac will work (not the best it ever did but enough) for around a hundred bucks. if you look around you can find it cheaper i bought that gauge set for $17 bucks and the pump for $9.
step 2 charge a couple people $50 each to fix their ac and you got yours for free.
Old 11-25-2011, 01:24 AM
kwren's Avatar
kwren kwren is offline
Fix the air conditioner... The air conditioner working correctly is part of the clearing of the frost on the glass year round.
Keith
Old 11-25-2011, 01:28 AM
kwren's Avatar
using $20 pump
retrofit kit $13
actually your first step should be to locate the refrigerant leak, if that is the problem, and fix that first, then simply get it recharged.
Keith
Old 11-25-2011, 09:22 AM
Keith
the last guy that looked at it though it was coming from the compressor...he had a sniffer and it was coming from there
Jared
Old 11-25-2011, 11:57 AM
kwren's Avatar
Sorry, the chances of there being any validity to that diagnosis are enormous.
Finding some "the last guy" that has any clue is so close to nonexistent that you could safely give "one million to one" odds against it.
I am truly sorry.
Keith
Old 11-25-2011, 12:35 PM
you can charge it with some r134a that has dye in it then use a blacklight to look for where it leaked out. about the easiest way to find leaks with little money invested because it's probably going to leak out anyway.
