Old 02-04-2012, 04:57 PM
Re: Vexine: 1992 SVX
So how does he check to see if it is the C solenoid or the basket? And how does he fix it. I know the. Answer do a 4:44 swap or. A 5 speed conversion. Guy needs help, he has entertained us . Needs a quick fix.
Old 02-04-2012, 05:30 PM
Green1995SVX's Avatar
Originally Posted by SubaruJawn View Post
also could disabling ABS effect the AWD ?
No. 7654321
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-04-2012, 05:32 PM
Get in the car, and with the door open, put the key in the ignition and turn it forward 2 clicks without starting the car. Listen for a noise from the transmission. It is a distinct fast clicking. That is the sound of the solenoid C. If you don't hear the noise, then the solenoid c isn't working. If you do, then it's the clutch basket.
My money is on the basket.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-04-2012, 07:16 PM
And I am guessing the basket means a blown tranny. Is it a fixable or better to just replace the whole tranny? Any estimate on cost of repair?
Old 02-04-2012, 09:07 PM
No, it can be repaired with the transmission in the car
Old 02-05-2012, 08:49 AM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
tried the key "on" position heard 2 click under the hood, and fuel pump run
upon start the POWER light blinked 17 times.
Old 02-05-2012, 09:35 AM
Sounds like u r still not down and out Jawn.!!! Can any machanic do this clutch basket replacement? Any cost estimate?what parts and where do you get them?
Old 02-05-2012, 10:09 AM
How to check trans codes is in the attached pdf.
Old 02-05-2012, 10:20 AM
I don't see 17
Old 02-05-2012, 10:23 AM
Blinking at startup is the car's way of saying "My tranny has problems! Please check what they are" (with a japanese accent of course). It's not the actual code.
Old 02-05-2012, 10:52 AM
SubaruJawn's Avatar
got my SVX 12-8-11
I don't see 17
15 would be the closest.
that beign the case, were is it ? what does it look like ?
EDIT:
finally found a PDF file
this can easily be replaced ??
