where did that wire go :[
my left tweeter had the original wire in the holder, but the right one had fallen down. i know it's somewhere lost behind the glove compartment, but how to i reach that? do i take the glove box out, or can i remove that side panel by the door? i don't want to break anything that doesn't come off.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: where did that wire go :[
It might be easier to fish a new wire through the door using a coat hanger. It's a good idea to run new wire anyways, as the original wire is old and may not suffice if you are powering your speaker off an amp. I think you said you were going to power them off the source unit, right? Either way, it may be easier to just run new wire.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
i'm running the door speakers off the stock headunit. i would run new wire, but isn't there a crossover built into the tweeter cables that only allows certain high pitched frequencies in? does the tweeter wire come from the door or from the radio?
You're going to be running new wire all over the place anyway. Are you using aftermarket tweeters or the stock ones? Aftermarkets should have their own crossover or high-pass filter anyway. You can probably get to the stock wire by reaching around in the hole.
i've been looking in there. what color is the wire? if you know. there's so much crap shoved in there. can i simply take off that side panel where the defroster comes out to the door? it feels like it's connected to the whole dash. and yes they are aftermarket. mine never had tweeters, just the tweeter holder.
If they're aftermarket, just run new wire, along with the crossovers or filters that came (I assume) with them. I don't think the stock tweeter wiring would have had a crossover or filter in line with the wiring, since it has its own output from the stock headunit. Just drop down the new wire through the hole and wiggle it around and grab the other end from below. That way you don't have to take apart the glovebox. I actually mounted the crossovers for mine just to the right of the glove box, by removing that little device that makes the glove box open slowly. They sit between the right side of the glove box and that grey panel with the vent that connects to the door vents. To do that you'd have to take out the glovebox though, which is a PITA. If you are going to attempt that, then ask how to first.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 01-30-2011 at 01:15 PM. |
