Old 09-13-2007, 09:42 PM
If you are using 2" pipe then get a 2bolt flange for each side meant to fit a 2" tube. I forget what the spacing is for the bolts... maybe svxfiles will know off hand
Old 09-16-2007, 12:25 AM
94SubieSVX's Avatar
OOC for a while
When welding the aluminized steel, is it any different than welding normal steel exhaust pipes? Will I need a special welder or anything?
bLAh
Old 09-16-2007, 08:42 AM
Try to do your best in wirebrushing/wire wheel the joints you are welding. Removing the aluminied coating makes it much easier to weld.
Old 10-03-2007, 10:00 PM
94SubieSVX's Avatar
OOC for a while
Changed my mind again and I'm getting it done by a reputable shop by me. Figured since my boss is good friends with the owner of the shop he can get me a nice discount. That and now for some reason I have a nasty buzzing coming from the tips at 2500+ rpms.
bLAh
Old 10-05-2007, 03:53 AM
dumpstafresh dumpstafresh is offline
just saw this thread thought id ad my 2 cents.
has anybody ever ran two 2.5 inch(or whatever the opening is on the headers or exhaust manifolds) pipes all the way back? no cats, maby mufflers. just a thought. then it would really be dual exaust right.
you would just have to put it on right after you passed emissions.
ive seen people do that with tuners. bout as loud as you can get.
Old 10-05-2007, 04:42 AM
actually I have heard exhaust with cats be louder than mine.... 2.5" all the way back from my custom equal length headers
Old 10-05-2007, 06:35 AM
sicksubie's Avatar
WHAT??????
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-05-2007, 07:00 AM
crazyhorse's Avatar
242,000 mi on oem trans
HUH?????Did you say something?
"42"
Current Stable By Age:
Old 10-05-2007, 09:17 AM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
Well, I dont think having true duals in a six cylinder engine would help on performance, I think it actually lose a lot of backpressure.
On V8 engines you can do true duals but still you have you usea an X pipe to help the gases from one side go out faster with the gases from the other side. Not to mention there's not a lot of room under the SVX to run 2 pipes.
My opinion.
Old 10-05-2007, 04:04 PM
no backpressure? does it loose any preformance. how does it sound.
im not a tuner or anything, why would you want backpressure?(serious question, not sarcasum)
i heard of needing backpressure on gocarts and such but not cars.
Old 10-06-2007, 03:42 PM
FI (Forced Inductions-turbo/supercharger) engines run better with minimal back pressure, because the goal is to flow as much air as you can with as little impediment as possible. Normally aspirated engines benefit from some in it's done properly.
Go-Karts used tuned exhausts (that big cone shaped muffler), which is meant to reflect the pressure from the exhaust stroke back toward the engine and have it give the pistons an extra shove by entering the cylinder while the exhaust valve is still open.
Old 10-07-2007, 01:00 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Has anyone tested to see if the Legacy GT cat-back meets up at all. Even just the axle-back maybe? I don't know I just want something other than a GIANT Camero looking muffler in the back. Makes it hard to get a jack under there.
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 10-07-2007, 02:46 PM
Speedklix's Avatar
Locker Link Solution
its really not that bad, you can't see my muffler at least. you can see the "U+/Mid-pipe". thats it, sortof unavoidable on an AWD with the diff in the way
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-07-2007, 02:49 PM
Speedklix's Avatar
I drove mine around the block a couple times with dual 2" res to 2.5 exiting cat... loud as hell, would scare a shelby off the road... but no power. finished the rest of the system, got it all back!
-Mike
[SIGPIC][/SIGPIC]
Old 10-07-2007, 02:52 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Our racer has no backpressure what-so-ever and it pulls like a semi... enough to induce 10" wide race tires to spin on all 4s through 1st and part of 2nd if you don't launch right.
