Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
  #256
Old 12-09-2004, 07:19 AM
Originally posted by Pure_Insanity8
Do you mean auto-leveling headlights? I'd give that one a big 'ol nope-erooni. I know my LS-L has manual controls for the headlight adjustments only.
Not autolevelling.
The Euro ones have a switch on the console beside the shifter. Just like this one on Sonar's car:
http://www.subaru-svx.net/photos/files/Sonar/14598.jpg
Essentially it has 4 settable positions, which you can adjust to compensate for heavy loads in the car causing the lights to aim high.
The switch activates a servo motor behind the headlamp unit which raises and lowers the dipped lamps.
Old 12-09-2004, 07:23 AM
Originally posted by svxistentialist
Not autolevelling.
cool, are those customized or standard SVX?
Old 12-09-2004, 07:24 AM
Originally posted by SVXtasy
Hi all
Today I drove my SVX-T, I revved it out.... And it is hot!
I accidentally hit 9psi and OMG it is so fast.
Truly it scared me.
I am not used to driving a car with this much HP.
It is like getting hit with a shovel.
It is so much fun!
You realize now that every time you drive this beast you will be grinning like a teenage boy on prom night!!!!
Old 12-09-2004, 07:28 AM
Lightbulb Bingo!
Originally posted by b3lha
Perhaps because of the legal requirement for rear fog lights (in UK). Maybe the stock loom didn't have enough capacity to power two sets of fog lights. It might have required heavier wire, bigger fuses etc.
Phil, I just twigged it.
Your approach was right, just thinking about the wrong loom. Bet you a Dollar to a pound of Matsuwhatsit that they are using the live wire for the front fogs to power the dipping servo motor. THAT is why they put a blanking plate instead of the fog lamp into the glass headlights.
You might also find out that there is a legislation problem somewhere in the equation also. Maybe the German TUV regs don't allow positioning of the fog lights right beside the headlights or something? [I often get flashed by fools thinking I have two lamps on, so must be on main beams]
Old 12-09-2004, 07:31 AM
Standard
Old 12-09-2004, 07:38 AM
Sonar's Avatar
Sonar Sonar is offline
... but I am not getting boost till quite late in the RPM band (like full @ about 5k in second gear) I accidentally hit 9psi (I need to adjust the wastgate) ...
-Sounds very odd..... the EG33 with stock "everything" should easily spool up that turbo earlier!
-Are you sure that the wastegate is really closing tight?
-There are no leaks in the exhaust or the "charge"/pressure side?
Are the manifolds designed for "flow" or "pulse"?
A "pulse" driven turbo often spools up faster/earlier than a "flow" driven.
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 12-09-2004, 07:47 AM
pure insanity mentioned something about additional injectors added with a controller for the turbo in SVXtasy, can't we just use bigger injectors instead?? and what is this system used???
Old 12-09-2004, 08:16 AM
mbtoloczko's Avatar
sans SVX
SVXtasy is using two auxillary fuel injectors mounted in the intake manifold. The injectors are controlled with an aftermarket controller. This is a very inexpensive and simple way to add more fuel when the turbo spools up.
Mychailo
Visit my locker
Old 12-09-2004, 08:19 AM
where can i find such a system? which is better (mechanically speaking) this one or bigger injectors?
Old 12-09-2004, 08:21 AM
drivemusicnow's Avatar
drivemusicnow drivemusicnow is offline
Poor College Racer
Send a message via AIM to drivemusicnow
with his experience he found it easier to control the extra injectors than it would be to control larger injectors..
any car can use bigger injectors with the proper management... its what kind, and how hard to setup that management is
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-09-2004, 11:37 AM
SVXtasy's Avatar
SVXtasy SVXtasy is offline
Turbo Member
Send a message via AIM to SVXtasy
When I started the project I could not find a good inexpensive way of controlling the larger injectors. Looking back I should have just gotten a set of Nissan 370cc and used Greddy EManage. EManage is a grate tool; it will also take away the problem I am having with the car stalling with the external BOV. Witch I can also fix by learning how to drive the car better. If have have any $ after I come back form x-mas I will look in to buying injectors and an Emanage.
Old 12-09-2004, 12:20 PM
mbtoloczko's Avatar
sans SVX
You may want to consider one of the Greddy Profec electronic boost controllers too. It likely to be the only way to control the boost spikes.
Mychailo
Visit my locker
Old 12-09-2004, 12:27 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
Your two problems of boost coming on too strong and not spooling fast are of the same beast i believe....there are ways around this though.
The car is running incredibly rich down low. The engine is bogging itself a bit and then when boost is created it fits into its power band and takes off like a bandit...and over boosts. This is typcially of na>turbo cars that we come into the shop without tuning. An hour or 2 of tuning(and a boost controler allowing you to control the gain of the valve like mychailo said) will make for a beast. If you would like to borrow a center diff and a rear diff to make the car rwd i can lend those to you as well.
phil
p.s. shoot me a pm
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Phast SVX's Avatar
Also what kind of MAF sensor do scoobies run, karmon or hotwire?
phil
~Phil
Old 12-09-2004, 04:16 PM
oab_au oab_au is offline
phil
It uses a hot wire Phil, though a Manifold Absolute Pressure sensor would be better for blown engines. Easier to accomadate the rise to boost.
One Arm Bloke.
Tell it like it is!
