Confirm Tran mount part #41022PA070
I have a bad tran mount (at the rear of the tranny) and from reading through the posts it looks like the part # is 41022PA070. Again, it is at the back of the tranny and it looks like I have to move the exhaust to get to it. Thanks for the help!
Paul 1992 LSl (Black Mica) 1965 Mustang G.T. Fastback 1990 Mustang G.T. Convertible 1986 1/2 Nissan 4x4 2004 Vovlo XC70 (wife's) Wonderful Wife Wonderful Son 2 Cats Incredibly blessed! |
That's the 2WD mount. If you have AWD then it's 41022PA081.
You should NOT have to drop the exhaust to change it.
If you safely support the tranny by the pan, (using of course a flat wooden board to protect the trans pan) remove the rear trans mount (6 bolts) and the four bolts from the mount to the trans, and the three holding the mount to the crossmember, it should wiggle out. Good luck.
Thanks!
Thanks! Now that I have my window fixed I plan on tackling other areas of the car.
