most check engine codes at once record. yah!!
allright ive owned my svixer for almost a year now and its still running good ( aside from the ticking that there sometimes and not others). i can still eat any honda or v6 mustang around. my check engine light has been on the whole time so i decided to see if i was throwing any new codes. i have a total of 6 codes. i think at least 3 of them are new. here they are.
11: (new code)crank angle sensor. (what does this mean?) 22: knock sensor(right side) left side was recently replaced. 23: air flow meter 32: (new code)O2 sensor (right side) 37: (new code)O2 sensor (left side) 56: egr system. What are the most important ones (im on a budget)? do you think any of these codes could have anything to do with the ticking from the right side of my engine? and i changed my water pump and timing belt all by myself (very proud thank you). do you think i could have triggered #11? feedback would be much appreciated,thank you. oh and i have a cone air filter instead of the airbox could that effect #23. witch would effect 32 and 37 mabey? |
Most important: Code 11, crank angle sensor. It read the angle of you engine crankshaft and uses that to calculate when to fire the spark plugs. If that goes your engine will not run.
Second: Code 23: MAF (Mass air flow sensor). Having this not in working condition will cause you engine to run poorly, as the amount of air coming in to the engine is not being correctly read by the computer. If it goes completely you engine will not run.
Chris is right.
With wrong signals from either of these two, the ECU may not have the timing and mixture right [optimal] If the mix is not right the O2 sensors will be seeing unburnt fuel and possibly setting codes. So you need to attend to those two first, do a reset, run the car and if the O2 codes don't come back you are OK. BTW, you should do a reset now [look up the How To section] and if your crank angle sensor comes up again, buy a new one. NOW Best of luck with it. Hopefully you won't need O2s Joe
I just pulled codes and got 11 and 37. I reset it multiple times as per directions and both came right back up again. So you're not alone...
i tried to reset it by sticking the blue wires in the 1st and 2nd slot on the connector. the check engine light flashed 12 and my fans were turning on and off. it didnt clear any codes at all. ill disconnect my battery and touch the -and+ together for a couple minutes like on a normal car. and i kinda searched, but any info on changing a crank angle sensor. do you think its just a bad sensor.
ok i cleared my codes drove it at least 10-15 dollars. and im down to 1 code # 22 i think that was the knock sensor right? do you have to take off the intake manifold to change that. if so im going go ahead to polish mine. theres one hanging on the wall at motorsports warehouse that looks good.
