Go Back   The Subaru SVX World Network > SVX Main Forums > Product and Service Reviews > Exterior Car Care Products
Old 09-07-2012, 11:16 PM
Re: Headlight restore
Originally Posted by Sean486 View Post
Does anyone have a clearcoat brand recommendation?
I am wondering if an anti-UV clear tint has the same effect as a clearcoat...
Any ideas?
Old 09-08-2012, 11:08 AM
SoobCrazy SoobCrazy is offline
SVX n00b
Consumer Reports rated the 3M kit the highest of the three resotration kits they used.
Old 09-08-2012, 11:23 AM
dbarnblatt's Avatar
You can avoid buying the kits altogether by just getting some 1500, 2000, and 2500 grit sandpaper and then finishing off with some Meguiar's Plastic Polish.
Start of 1500, go to the 2000, then 2500, then use the plastic polish on a random orbital polisher to finish it off.
A lot less money (I think I spent $15 for the sand paper and the polish) and you can do multiple cars with supplies left over to do tail lights, corner light etc.
Old 09-08-2012, 11:45 AM
I'm ordering a sheet of Lamin-x film to put over them for when they are done. I was searching the net for a UV clear coat paint but there doesn't seem to be a good one to use.
Old 09-08-2012, 11:51 AM
That seems like a good idea. Where did you order it from?
Old 09-08-2012, 12:09 PM
I haven't actually ordered it yet, but I will be ordering it right off the site. They don't have it precut for our cars like they do for some other makes, but I figure 2 8" x 16" sheets will work.
I am just going to order the clear although I was considering the smoked.
http://www.lamin-x.com/Two-Universal...rs-p/2-816.htm
Old 09-08-2012, 03:15 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Just don't do what I did. Tried to precut shape, with backing on, over a spare set of headlights. The lens curve really throws off what is a basically a simple parallelogram shape. Now I need to reorder, install, and then cut after all is right.
Gene
Gene and Ben
Old 09-08-2012, 04:14 PM
Gene
Gene,
So what is your plan, are you just going to put it on oversized with the heat gun then trim it down?
Old 09-09-2012, 02:37 PM
bwb3's Avatar
That's it. I am going to start with a hair dryer but, I do have a true automotive heat gun (or I should say my son does). I was initially afraid of stray cut marks on the lens and less than prefect edges. Would you recommend masking tape and an artist's Exacto razor knife?. Material wise, will also plan for one more failure since I am all thumbs.
Gene
Gene and Ben
Old 09-09-2012, 04:54 PM
Gene
Yeah the Exacto was my plan as well, I am going to try to find a flexible metal straight edge to run the knife against. Trim as close to the edge as I can. How hard could it be? What mil thickness are you getting? By the way what size sheets did you originally order?
Old 09-09-2012, 05:14 PM
I ordered a pair of 20 mil 8x16" sheets. Hoping it will be enough to do both the headlights and turn signals. If this stuff is anything like vinyl, it will be much easier to do than my carbon fiber wrap on the interior was, since the headlights are a big, mostly flat surface.
I'll probably take off the headlights, polish them, wrap the film past the edges on each side, and cut off the excess leaving ~1cm on the sides.
Old 09-10-2012, 10:27 AM
bwb3's Avatar
I purchased mine from X-PEL.com and it was 30 mil. Lamin-X.com looks like a better deal and maybe easier to work with.
Gene
Gene and Ben
Old 09-14-2012, 10:20 AM
fzftw's Avatar
fzftw fzftw is offline
Just dip a toe!
This was developed by a local friend of a friend. Easy, works great, cheap, lasts forever.
http://youtu.be/A7UYfa9JnNM
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
Old 09-14-2012, 11:12 AM
I doubt that.
Old 09-14-2012, 02:20 PM
fzftw's Avatar
Just dip a toe!
It has a lifetime warranty. I haven't kept a vehicle long enough to personally see the results but we have customers who have had it done years ago and they still look the same.
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
