Old 08-11-2007, 07:36 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
movement in rear wheel assembly
If you jack up up the car, take off the tire, you can move in and out the whole hub assembly on the drivers side about 1", and the halfshaft moves with it. However there is no road noise at all, but it doesnt move in and out like that on the other side..
Any ideas what this could be? Should I be overly concerned about it?
1992 Subaru SVX 5spd
1998 Pontiac Firebird Formula
1999 Chevrolet Camaro SS
2009 Subaru Forester - Mileage Junky
2009 Pontiac G8 GT
2017 Ford Mustang GT 6spd
Old 08-11-2007, 10:23 PM
I know there's the "passive all wheel steering" deal that always comes up, but 1" of play seems a bit much to me. What sort of shape are your suspension bushings in? Does the other side do that too?
Old 08-12-2007, 12:46 AM
so are you saying the axles moves but the hub doesn't?? Thats a major issue and I would not drive the car in any case until it is resolved
Old 08-12-2007, 12:50 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Is this on the teal???? If so, I'll find out what it is when I come pick it up hopefully tomorrow. 1" is ALOT and I'm quite curious to see what it could be to cause that kind of play as I didn't notice anything wrong a few months ago when I was working on it. Get ahold of me about us coming down Sunday(today).
Old 08-12-2007, 08:39 AM
Classic SVX
Not the teal. Surprisingly!
I think it makes me more sad that it is not the teal though.
There is no noise coming from the rear of the car. It seems perfectly fine driving down the road, but when I was taking off the tire I noticed it had play, and when I was pulling the rotor off I REALLY noticed the play. I tried moving the other side and it did not have nearly that much movement.
Not sure what would cause this?
2009 Pontiac G8 GT
Old 08-13-2007, 11:18 PM
Budfreak's Avatar
Banned
Problem solved. Whoever the last person was to tighten the axle nut apparently thought it was tight enough when it still had 3 turns to go to even be snug. Tightened it down and it's good to go.
Old 08-17-2007, 09:58 AM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Jason,
We have found that EVEN WHEN PROPERLY TIGHTENED AND TORQUED, the axle nuts do have a tendency to loosen up (not 3 turns, though ). It' one of the things we check any time there's an unusual vibration.
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
