Old 07-19-2009, 09:25 PM
y2daniel1981's Avatar
y2daniel1981 y2daniel1981 is offline
Re: What boost can you run on a stock EG33 motor?
Originally Posted by TomsSVX View Post
Seriously, I don't know why you are being so stubborn. The engine can be used in different cars. Does that make it not a stock engine anymore? I am not beating a dead horse here. When I was in college learning about being a good teacher they told me a couple things. One was that some people learn by experience. Some people learn through description. Another was that some people learn from repetition. Sooooo I tried to do all of those and you still don't get it. A honda with an intake is still a stock engine. A subaru with a cat-back still has a stock engine. An SVX w/ a supercharger, custom manifolds on both ends of the engine, injectors, ( I hope you see where I am going here) all put on a stock engine STILL has a stock ENGINE. It has different things attached to it. Those attachments are accessories to the ENGINE. So if you say a stock engine cannot have anything attached to it that was not original equiptment, then there can be NO boosted stock engines in the world, by your definition of course.
Hey guess what, I'm working on my Master's in Secondary Education so I know all about the diferent learning styles and such. I have got A's in all my courses so far. Just because I am debating you do not think you can throw it back at me saying that my students will be doomed. If students are not free to ask questions to try to understand then it is doing them no good to say "you just don't get it, this is the way it is because I say it is like this." I am saying, "here is point of view and here are my reasons." Did you also learn to see from the student's point of view to see why they are not getting it or that you should not limit yourself as a teacher with your methods? Make me your student, teach me then if I am so absolutely wrong. If you can change my point of view, then job well done, but until you can make me believe your way of thinking, I am sticking to my beliefs.
If you pull an engine, all it's accessories, and computer/wiring out of the SVX and put it in a honda, then it is stock because in no way has the way the engine operates been altered. And yes by my definition even adding some sort of F/I makes an engine not stock, even if just the F/I mechanism is added and nothing else, because it again is no longer factory stock as to operations of the engine. Hell if you throw a K&N air filter in the airbox the operations of the engine are no longer stock, change the gap of OEM spark plugs and it is no longer absolutely stock as there has been an alteration, even though ever so slight, to how the engine operates.
Old 07-19-2009, 09:44 PM
Engine.... Engine Management.... Lets break this down here. An engine needs engine management to run. But is the engine not an engine anymore without it? So all those people selling engines on ebay and where have you are lying because you cannot start and run it on the crate? I do realize you are trying to prove a point here. BUT the point is for no good reason other than to contradict what I have said thus far. So now that you are going for your masters, Sorry I only have my BA for secondary hist., at what point will you realize if you try this with your students you will only look like you were defending yourself and not your point? I have said my piece and backed it up with evidence of my experience to answer the question asked. I will no longer contribute to this mockery of a debate.
Old 07-19-2009, 10:25 PM
evilsvx's Avatar
evilsvx evilsvx is offline
tom, how much whp where you pulling on 9psi setup. doesnt also affect the type of turbo you are using in order to setup the amount of psi
Old 07-23-2009, 07:45 PM
SomethingElse's Avatar
word words wording
GRRRRRRRRRRRRRR me no like engines...make me angry engine go vroom
This reminds me of the Budfreak and DaveyGravey days...without all of the.... ***** !!! im gonna **** your mother and **** spill blood out of your ****ing kids and slit your ****ing throat then grab my **** and balls then dip them in your ****ing mouth and piss down your ****ty neck mother ****er all while ****ing your girlfriend in front of you!
well kinda
Eric
Old 07-23-2009, 09:15 PM
I can haz vroom?
Old 07-23-2009, 09:25 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Here's a hot idea - what if we make our standing question perfectly clear?
Let's say we're running with a stock block, stock heads, stock pistons, crank, valves, and all other internals. Given that a compressed intake charge is stuffed in there, how much pressure can it handle?
I think that's the question at hand. The ECU, air conditioning, muffler, air filter, and taillights (related via alternator omg!) don't count in this scenario!
Old 07-24-2009, 12:46 AM
It's Just Eric's Avatar
Missing in action
The whole stock and not stock....
Pressure is pressure, regardless of what has been done to improve overall cfm's of air passing throught the engine. Stock would refer to the stock internals, as the exhaust and intake would be modified in a tubrocharged setup anyway.\
The stock ecu is the first bottleneck in a f/i set up. You can cram as much extra air into the cylenders as you want...It isn't going to help if there's no more fuel going in. The air to fuel mix will run lean, and the engine will pull timing to compensate. The point it is safe to run boost without a mechanism (ecu, or in the olden days, bigger injectrs and fuel pressure regulators)adding any extra fuel... I couldn't tell you. With the proper fueling and timing safeguards in place to prevent detonation, engine's stock internals, sensors, miscelanious bolt on equipment and all of their sub divisionaries and affiliates can handle 9psi safely.
R.I.P Cool Signature.
Old 07-24-2009, 06:30 AM
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
