Old 02-08-2013, 09:02 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Cruise controll on MT?
Just woundring can you get cruise controll to work on a MT svx?
And is that mutch work? and is the a set up do doo this?
It have been cool to get this work on my car when i take it out this summer.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 02-08-2013, 09:27 AM
Re: Cruise controll on MT?
Yea it is doable. You need to have the clutch switch set up in place of the neutral safety switch, if it's not already. Other than that, it should work without any changes to the original setup. Make sure the hose from the cruise control vacuum pump is connected to the diaphragm that pulls the cruise throttle cable. Those often come off.
As it is now, does the car start only when you push the clutch pedal? And is it RHD or LHD?
Old 02-08-2013, 01:40 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
It does work fine- you do need the proper clutch pedal switch for it to function though. My 5-speed when I got it would start regardless of the pedal position (was wired across the switch) and the switch in it was closed at the wrong position for the cruise to work. Easy fix.
Old 02-08-2013, 02:08 PM
Mine works like it was factory. Starts with clutch is pressed to the floor only ,and when in cruise if you touch the brake or clutch it cancels cruise.
Old 02-09-2013, 03:44 PM
Alex-svx's Avatar
Ok. I have not test it i was sure i must have wired up to get this to work.
And my speedometer have also not work. (This work now)
I have a LH car. and the car start whitout pressing the clutch pedal.
Alexander (Norway)
My subarus:
Old 02-11-2013, 08:23 AM
It was covered in my write up....
