Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 05-25-2011, 12:33 PM
longassname's Avatar
Just some dude.
Significant Technical Input
ECUtuner software and Select Monitor Interface
This post is just a place holder to start the thread so I can make links to it. I'm going to go ahead and release the ECUtuner software. I haven't gotten a chance to add in the table editing or ROM emulation features yet but the software already has more functionality than a Subaru Select Monitor, namely:
1)check and clear trouble codes
2)monitor all the same parameters a select monitor can
3)download the firmware from any compatible control unit (ie: any obd1 Subaru ECU or TCU, older polaris watercraft and snow mobiles, older harley davidsons, etc)
What is the ECUtuner software? It's a windows application. I wrote it/am writing it in Microsoft Visual Studio c sharp. It should work on any laptop with any dot net enabled Microsoft Windows operating system and a USB port. It also requires an appropriate interface cable.
What is the appropriate interface cable? An FTDI TTL-232R-5V plus an ECUtune OBDI inferface with a Subaru Select Monitor plug on it.
The ECUtune OBD1 interface with the Subaru Select Monitor Plug on it is available for $79 on the ECUtune website: http://www.ecutune.com/ecutuner.htm
The TTL-232R-5V is available on the FTDI website: http://www.ftdichip.com/Products/Cab...BTTLSerial.htm
You will also need to download and install the d2xx drivers while you are there: http://www.ftdichip.com/Drivers/D2XX.htm
How much does the ECUtuner software cost? It's free to use. How much product support should I expect or demand from its author, Michael Emery? None. You guys will have to help eachother if and when you run into problems and hopefully you will develop a community knowledgebase both to guide new comers and to spur future developments.
Old 05-25-2011, 02:30 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: ECUtuner software and Select Monitor Interface
This sounds awesome and is something I'm really looking forward to.
Old 05-25-2011, 06:11 PM
Just some dude.
Ok, it's posted. Get your interface and download your copy of ECUtuner here: http://www.ecutune.com/ECUtuner.htm
Old 05-25-2011, 08:57 PM
SVX n00b
No OBDII version? Are 96-97 svxi doomed to stock ECUs for all of time?
Old 05-25-2011, 09:40 PM
Almost. I think a Hydra will work on them too. Also you can technically run anything on a megasquirt if you can calibrate the sensors for it but it would probably be too difficult to keep it an automatic.
Old 05-26-2011, 06:05 AM
Huskymaniac's Avatar
Uses the ignore feature
Couldn't someone build an OBD2 cable that would interface to this board and the SSM pins on the OBD2 port?
Tony
