Trouble starting my 92 svx thats been sitting for two years.
Here is what I have done:
1. new battery 2. change oil and filter 3. change tranny fluid and filter 4. change air filter 5. change crank angle sensor Here is what I have checked: timing belt, spark plugs and wires (one is cracked near coil, no spark though) You guys have tought me about the 10 pin diagnostic connector and the blue wires and near the left foot of driver behind the pannel (thanks) i connected the blue wire into the second spot from the left on the top row which was told to me to be the (#2) spot and used to read the memory. i followed the diagnostic directions further which was to try to start the engine and stop and count the number of times the check engine light blinks (long blink means 10, short blink means 1) I saw 2 long blinks and 9 short blinks, (29) I then looked at the list down to number 29 and it read exactly "Crank angle sensor" So I went to Autozone and ordered the part *Autozone calls it a crank position sensor* and when it came in I installed it and didnt start. I rechecked the diagnostic the same way as stated before and i am getting the same reading (29) Q: What else is good to do to this car cause its been sitting? Q: How do I check to see of the cam is rotating? Q: Would a blown motor cause this? Q: Was I given misguided diagnostics code meanings? (same as the ones in how to docs link on this page) Q: Is it possable that the new sensor was bad also? (it was given to me in a labled ziplock and the bottom of the round shiny part that goes into the engine has a slight fingernail indention. *not sure if i caused this or it was done prior to me picking it up. -------PART TWO OF PROBLEM ONE------------------------------- I have two leaks sence changing both tranny and oil fluids and have separate questions for each. Both leaks are happening without the motor being able to run. 1. the first leak is coming from the bottom of the seal of the plastic coverplate behind the wheels and belts, it looks like tranny fluid and the seal doesnt appear to be a fluid retaining seal. Q: Where is the tranny fluid coming from and how do I fix it? 2. The second leak is coming from the valve cover on the passengers side and its definately oil. Q: How hard is it to replace the valve cover gasket and will I require any special tools other than a regular socket set with the elbow addapter? I would greatly appriciate any input or requested questions about these matters. I am very excited about this car!!!!
92 SVX-LS, BLACK, 189k Fiona |
Try leaving the battery disconnected over night and then try starting it the next morning (after reconnecting the battery, of course). It is possible that the ECU doesn't recognize that you've replaced the faulty sensor.
-Bill
The battery stays disconnected unless I am trying to start her up...
when both blue wires are connected to the number one and two terminals on eth diagnostic connector, the engine light blinks the code 12....nowhere do I read that a code is given when both blues are pluged, only that its supposed to clear the memory of old codes that have been repaired. Reguardless of the crank angle sensor I replaced and the fact I cleared the old code and disconnected and reconnected the battery, it still reads the same code (29). Is it a blown engine???? Can anyone out there tell me how I can find out if my cams are rotating or not? Thanks
92 SVX-LS, BLACK, 189k Fiona Last edited by ricktheseabee; 01-18-2008 at 02:56 PM. Reason: additional comments |
Try clearing the ECU's memory by inserting both probes into the test connector as noted in the "how to" document and then see if you still get the 29 code.
-Bill
Keep your fingers clear!
What type of sparkplugs do you have on the car?
My ebony wouldn't start even after I replaced the timing belt, o2 sensors and swapped all three cam/crank sensors and the ignitor. Turned out it was just the cheap Autolite plugs I had put in it 2-3 years back. New NGK plugs are in now and it starts up with no problems at all. Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
ok, tried to clear the memory again and still getting code 29, also removed the timing belt cover just enough to see it moving while a friend was turning the key.
Does this mean my engine is not blown, cause thats my main concern, I inherited this car recently and am crazy about it! The sparkplugs are cheapies....I will replace those but it doesnt look like that will be a fun day. I will print directions from the How-To link above.
92 SVX-LS, BLACK, 189k Fiona Last edited by ricktheseabee; 01-18-2008 at 03:22 PM. Reason: additional comments |
