Old 06-14-2007, 03:56 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Jet powered kart on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230141656422
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 06-14-2007, 07:39 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Test
Wonder if test drives are allowed?
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-14-2007, 09:02 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Neat, however i see no location for fuel... Am i missing it? I'd want to know that it actually works, videos, etc.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-14-2007, 01:39 PM
The metal box to the right of the seat.
This thing would be AWESOME!
Old 06-14-2007, 02:01 PM
HumpSVX's Avatar
HumpSVX HumpSVX is offline
Send a message via AIM to HumpSVX
I won't be surprised if this thing ends up somehow being involved in a Darwin award
-Hump
'99 RBP Subaru Impreza 2.5RS
'92 Pearl White Subaru SVX - 136k - My first SVX -traded
'92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible
'92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine)
Okay, so the bottom two cars don't actually exist but what if?????
Old 06-14-2007, 02:05 PM
budbaer's Avatar
budbaer budbaer is offline
Send a message via AIM to budbaer Send a message via Yahoo to budbaer
That is INSANE! I've wrecked cars, motorcyles and was even in a plane crash once, but I would not want to be in that when it takes it's last ride.
Old 06-14-2007, 02:40 PM
92svx95 92svx95 is offline
you just have to gooo eeeaasssyyy!!!!! the "ad" did say it handles as if it were on rails?
Old 06-14-2007, 03:56 PM
HumpSVX's Avatar
I never understood "handles as if it were on rails." Does that mean you just hold on for the ride while it goes a predetermined direction???
-Hump
Old 06-14-2007, 04:07 PM
b3lha's Avatar
Phil & Belha
Seems like it's not the only one in existance......Some interesting commentry too.
http://aardvark.co.nz/pjet/gokart.htm
Yes, I finally took the kart out for a spin with the 100lbs-thrust pulsejet engine -- here's what happened:
As I expected, pure thrust is not the best way to power a gokart -- at least not on roads like the ones around my place.
My "test track" consists of a gravel road where the straight sections are not flat and the flat sections are not straight. It's worth pointing out at this stage that I weigh about 170lbs and the kart weighs about 90lbs when ready-to-roll. This represents an all up total weight of about 260lbs (depending on how much I've just had to eat).
Now, with 100lbs of thrust, that gives me a 1:2.6 power to weight ratio. While this is significantly more than your average passenger plane -- it's not as high as a jet fighter and, more importantly, it means that if I encounter a slope of more than a 1 in 2.6 gradient -- the kart will begin to slow and eventually stop.
It's also worth pointing out that jet engines tend to become more efficient as their speed through the air increases. They work by propelling a narrow column of hot air at very high speeds. Think of it like top-gear in your car - plenty of speed but not much acceleration.
As a result of this, the jetkart feels quite sluggish when moving away from a standing start. You can feel a gentle push moving you along but it's certainly not a "kick in the pants."
However -- and this is the tricky bit -- it very much feels as if the faster you go, the harder the kart accelerates. Indeed -- once I got up to about 30 mph that gentle push had turned into quite a noticeable shove and the kart was gathering speed at quite a rate.
As I said though -- the roads around here are not built for speed so I had to limit my bursts of power to the short (100 yards) between the tight corners and big dips in the road.
http://www.nickhaddock.co.uk/jetkart.htm
http://www.jetkart.co.uk/
http://aardvark.co.nz/pjet/turbinenuts.shtml
http://www.dangerouslaboratories.org/kart.html
Since the Jet-Powered Go Kart was a bit underpowered and slow, our engineers decided to mount the Gluhareff G8-2-20 Pressure Jet on a 1990 Cannondale SM-500 Mountain Bike. This worked out quite well. The top speed was approximately 28 miles per hour on level ground (without pedal assist).
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260126457222
Old 06-14-2007, 04:26 PM
An autocrosser here states if it handles as if it were on rails you're not going fast enough.
