Timing belt info
So, err, someone asked me a question via PM and I don't really like answering questions without others able to correct me, so I'm going to post it here instead.
Change the water pump, thermostat, and the gasket for each at the same time, as well as the cam seals, crank seal. It's kind if a pain to change the belt, so might as well do everything while you're in there. Optional, but recommended. Also check out the two accessory belts and the radiator hoses since you're taking them off anyway. That big black plastic thing at the front of the engine behind the big pulley? That's the timing belt cover. Either of the two side pieces can be removed to look at the belt. It's not that bad to do it yourself, but it's not the easiest thing in the world. Depends on your level of experience. I've found it's easiest to do it with the radiator out of the car, and you gotta empty the coolant when you do the water pump anyway. The hardest part is getting the crank pulley bolt off. Anything anyone else would add?
Re: Timing belt info
well, when it comes to browsing this forum and finding useful things about the car, you won't have a good time. so i was trying not to make it worse
anyways, no way to see how much it had worked? is it fine if i buy the replacement parts from ebay? no need for special tools? |
I do understand the sentiment.
Depends on your idea of "special tools". The crank pulley needs a 22mm socket and a breaker bar helps. Other than that you just need regular mechanic tools. You'll also need a vice to compress the timing belt tensioner. There was a thread a while back just on getting the dang crank pulley bolt off. The ebay timing belt and pulley kit will suffice, but I prefer the subaru OEM waterpump. The gaskets and seals and stuff should also be pretty cheap from subaru. subaruparts.com and 1stsubaruparts.com are good sources, even if they do take a while to ship sometimes. Auto parts stores don't have proper pre-bend coolant hoses, but they should have the accessory belts. I'll look around and see if there's a nice how-to around here somewhere. If there's not one there should be.
http://compare.ebay.com/like/2507298...=sbar&_lwgsi=y
i use this to get the crank bolt off at home, easy to work with little clearance and it's cheaper than an impact gun. |
The "Big bolt" is the easiest part... get your Break over bar, big socket, put socket and break over bar and place on the bolt... rest the break over bar on a padded cushion on the fender, and turn the key to start.
Another thing... make sure you use the correct fender! Works like a dream! Keith |
just one thing...does it turn clockwise or CCW? cuz some cars are weird! |
