Old 05-04-2014, 09:29 PM
Did you ever wonder why...?
They flattened the shape of the rear wheel arch for production cars?
The original prototype had round arches, which looked better with the wheels.
A last minute design change by Giugiaro? Subaru?
Old 05-04-2014, 11:53 PM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: Did you ever wonder why...?
I really like the proto type.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 05-05-2014, 12:13 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
I was JUST thinking about this. It would make our cars look a lot less like they had a saggy rear end, too.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 05-05-2014, 03:02 AM
'E''s Avatar
'E' 'E' is offline
after looking at the prototype and the real car i think the reason is that the production car is shorter then the prototype hence the flattening of the arch, if it was round it would have eaten into the body line of the flare. if you look at the front you'll notice there is a lot more guard then the production model
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 05-05-2014, 03:28 PM
dbarnblatt's Avatar
Seems to be a change by Subaru for the show/concept car. Earlier style models by Guigiaro shows a car that is very close to what the production car ended up looking like. Plus I think Guigiaro preferred the simpler look with no wing and more integrated flares.
Old 05-05-2014, 04:40 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
An opportunity missed IMHO. The equal cutouts look so much more balanced.
Gene
Gene and Ben
Old 05-06-2014, 06:17 AM
The squared off arch is a very dated design cue and something I'm not a big fan of. I suspect though that it may contribute to the car's aerodynamics. From what I've been able to puzzle my way through the upper rear area of a wheel tub is a high pressure zone, and having a larger opening in that corner while squaring off the top to minimize the overall open area might give the best ventilating effect and reduce drag.
*disclaimer: I'm no aerodynamicist, this is just my suspicion from eyeball and some research.
Still, I think it looks like junk, particularly on a lowered car.
Here's one of the sketches I've done up for the restoration of my car. I intend to raise the top of the arch slightly and fill in the flattened area to create a round profile that resembles the front wheel. This will also entail modifying the bumper and skirts to help fill in the open space:
Once I complete my 3D model of the SVX I'm hoping to use it to perform some CFD analysis and comparisons to the body modifications I want to do. I'm not worried if I don't match the .29 cd of the real car, just looking for comparative analysis. It would be interesting to see if that sheds any light on the design of the SVX.
Old 05-06-2014, 08:18 AM
I actually Like the flatter Arch on the SVX, it goes better with the body lines, but to each their own.
