Old 10-04-2007, 04:12 PM
cruisen_15's Avatar
Exclamation bad alternator??
at idle my alternator only shows a flat 14.00v , i heard u want 14.2, anyony think i should have it load checked at a schucks or somethin?
Old 10-04-2007, 04:47 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
Sounds totally normal to me. It'll charge at anything above 13.4 (or is it 13.7?) I believe.
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 10-04-2007, 05:10 PM
It varies depending on what you have running at the time. If you check while you have the headlights, A/C, radio, and everything else going, it's going to read lower than normal. Anything between 13 and 15 is fine.
Old 10-04-2007, 05:46 PM
Manarius's Avatar
Manarius Manarius is offline
As long as you aren't getting the charge light, you're good.
-Jason
-Obi Wan Kenobi
Old 10-04-2007, 06:32 PM
subarufamily subarufamily is offline
as long as the altenator is still putting out more than 12.5 volts at idle you are good to go
Old 10-05-2007, 12:28 AM
kwren's Avatar
kwren kwren is offline
14 volts
count your blessings and "if it works, don't fix it!" If it doesn't continue this great performance, it will let you know in time to fix it!
Old 10-05-2007, 08:18 PM
elvis elvis is offline
Actually, I have recently been stranded twice with a dead alternator. Yes, the replacement died a week after it went in.
Idiot light never even flickered. I know it's not burnt out because it lights when starting the car.
I had the simmilar electrical symptoms on my 1st SVX (bought new in '92). Replace the battery several times thinkng that it was the problem. Ended up selling the car.
Old 10-05-2007, 09:02 PM
Manarius's Avatar
That's weird. Everytime I've been in a car with a failing alternator, it was blatantly obvious that it was failing and we went home right away...
-Jason
-Obi Wan Kenobi
Old 10-05-2007, 09:21 PM
kwren's Avatar
Chances are....
[QUOTE=elvis;498169]Actually, I have recently been stranded twice with a dead alternator. Yes, the replacement died a week after it went in.
Yes, Chances are that without the idiot light coming on the original alternator you replaced with the replacement that only lasted a week, neither of the alternators were defective.
Old 10-05-2007, 11:26 PM
"Idiot light never even flickered." Illuminated? "Dead alternator" What was the exact nature of the fault?
The alternator fault light will illuminate in the event of any of several faults within the alternator. An IC is incorporated to this end. The light is not configured the same as the old type of charging light, which became known as an idiot light, due to the ammeter which it replaced being the preferred option.
The light is energised positive via the ignition switch and comes on by way of a true test when the engine is stationary. Proper functioning results in the ground circuit being broken via the included IC, as soon as the alternator produces voltage within a basic criteria.
In the event that the light does not illuminate with the engine running, this should positively indicate that there is no basic fault within the alternator, including any fault involving the IC.
Old 10-06-2007, 12:39 PM
kwren's Avatar
Trever,
that is what I just said
Old 10-06-2007, 03:06 PM
Not what I said. Read again. I put forward three specific questions, which if answered could throw light on an issue which has been placed in doubt.
Old 10-06-2007, 07:36 PM
kwren's Avatar
Trever...more....
Gibberish. We just want the simple information that helps our SVX's to stay on the road
Old 10-06-2007, 08:58 PM
To some a simple technical information is obviously gibberish, but not to all. It would be stupid if enquiries into technical matters, exceeding the understanding of some, should be disallowed based on the arbitrary wants of the prejudiced.
Here a useful piece of information is involved. This constitutes possible knowledge as to whether the test system in the alternator is, or is not, fool proof. It is possible that the IC could fail to an open circuit. An answer will comprise valuable, "simple information that helps our SVX's to stay on the road."
