Old 10-28-2007, 11:19 PM
j_hustedt@hotma j_hustedt@hotma is offline
Vendors for transmission resistor
Hi all,
I'm looking to pick up a new spec transmission resistor. Any suggestions where I could pick one up or order one?
Thanks!
Old 10-28-2007, 11:46 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by j_hustedt@hotma View Post
Hi all,
Thanks!
What do you mean by a "new spec transmission resistor" ?
Trevor, New Zealand.
Old 10-28-2007, 11:47 PM
Something roughly equivalent to the original stock resistor.
Old 10-29-2007, 12:00 AM
Trevor's Avatar
Check the How Too stuff here.
http://www.subaru-svx.net/photos/files/How-To/31030.pdf
Old 10-29-2007, 05:39 AM
CorSVXette's Avatar
CorSVXette CorSVXette is offline
SVX- My daily driving Corvette
Send a message via AIM to CorSVXette
Classic SVX
How do you know when your resistor needs to be replaced?
Paul
1969 Corvette
1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS!
1995 Corolla
2003 Highlander
Old 10-29-2007, 05:49 AM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
Your transmission will shift abruptly, you will lose engine braking (put the shifter in '3' going down a hill and take foot off the gas; your revs will plummet), and most noteably your Power light will flash 16 times upon startup. This notifies you that there is a transmission fault.
http://www.svx-iw.com/svxiw/article/?article=79
The link above will tell you how to pull codes. If your resistor is dead, you'll get a code 11.
Old 10-29-2007, 06:08 AM
It is located between the battery and the inner fender under the hood.
If you remove the two 10mm head bolts that hold it in, you can check the resistance with an ohmmeter.
Good stock resistors will test at, or very close to 12 ohms. Factory range is 9-15 ohms.
If it reads as an open circuit then it is very bad.
Old 10-29-2007, 06:49 AM
Nomake Wan's Avatar
Retired
Mine read open circuit when it was removed and tested too.
Old 10-29-2007, 05:06 PM
gsodonis's Avatar
gsodonis gsodonis is offline
My 5 speed doesn't need her resistor
You can have my stock resistor if you want it. I have a 5-speed and the PO left it on the inner fender. Pay shipping and it's yours.
