Old 11-17-2014, 09:13 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
So..spacers, and EGR delete plates I have to make?
What is the group thought on the TB spacer as part of this package?
Yay or nay?
I will figure out pricing this week.
If I don't get at least 10 takers it may not happen, so spread the word! I think we are close already..
Thanks guys.
'20 Honda Ridgeline
http://www.x35design.com
Old 11-18-2014, 10:54 AM
dseventing dseventing is offline
No on the EGR delete, maybe on the TB, definite yes on the phenolic spacer. What kind of price are we looking at for the package of the TB and phenolic spacers as suppose to just the phenolic spacer?
Thats just me though.
Old 11-18-2014, 10:19 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Yes on the TB spacer!
EGR delete maybe. Stretching out the EGR Tube can't be that complicated
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 11-23-2014, 05:06 PM
Stevebsy's Avatar
Administrator
Ok..here is my pricing proposal for 8mm thick phenolic spacers:
Option 1:
Intake manifold spacers only, one set= two pieces, with a set of 14 extended bolts, the price will be $99 shipped.
Option 2:
Set of two intake spacers, plus throttle body spacer, plus 14 extended bolts for intake and 6 for the throttle body. $125 shipped.
Option 3:
Throttle body spacer only plus 6 extended bolts $35
At this point, I do not want to get in the gasket selling business, so I will find the PNs and point you at a few sources, or you can use your favorite sources.
As to the EGR - One option is to cut the tube and use a compression union fitting to reconnect the two halves, assuming there is enough of a straight section to do this. The other option is a set of block off plates, one at the intake manifold and one at the exhaust, which may not be permitted in your city/state, check before deciding. I have also seen other manufacturers saying that you can just put a piece of rubber tubing to reconnect the tubes, or you can stretch the tubing as described by Svxfiles.
The cost for either of these solutions should be about $15, but I want to get a set of spacers made up and experiment on my car to see what is best.
In order to move things along a little quicker, I will give a $10 discount on the first 6 prepaid orders of option 1 or 2.
As soon as I have at least 4 prepaid orders I will order the materials, expensive special milling cutting tools, bolts, make some fixtures, etc.... and get to making that nasty dust
Paypal address is paypal@x35design.com Please include your forum name so I can keep track of y'all.
PS When I say $xx shipped, that means in the USA. For shipping to Canada, please add $8 to the prices. I will do export orders, but please contact me with your location so I can figure out shipping costs.
Who's first?
'20 Honda Ridgeline
Old 11-23-2014, 06:04 PM
Just for the record, My 1992 Claret has had an EGR bock off plate for YEARS with out an check engine light. I did this not because of the 8mm bottom phenolic spacer but because I installed/built headers.
Since I am not in a check your tailpipe state this has not been an issue with me.
More on this later...
Old 11-24-2014, 11:22 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
When I installed my phenolic spacers from Outlaw Engineering, I was able to bend my EGR pipe to fit since the pipe is a "Z" shape from the factory anyways.
Also, if you still have coolant lines running to your TB, you MUST use a phenolic throttle spacer in conjunction with the intake spacers or else the intake spacers will be useless as your intake manifold will reach engine temp from the coolant flow through the throttle body.
Ask me how I know this
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 11-25-2014, 12:21 AM
Smile Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
I will be sure to send you money in the morning. Thank you for doing it, can't wait to get them and put them in the car
Old 11-25-2014, 02:03 AM
OKEYDOKEY, Please send your monies to, oh crap! Do you think Stevesby will read this?!?!
Nevermind!
Old 11-25-2014, 08:44 AM
Talking Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
Money sent
Old 11-26-2014, 09:34 AM
theflystyle's Avatar
Just to confirm, is the EGR #8 in this picture?
1994 SVX LSi
2008 Legacy 3.0R
Old 11-26-2014, 11:29 AM
Svx95's Avatar
eg33svx95
#1 is the actual Valve assembly EGR control.
#2 is the plate complete EGR valve.
#4 is the EGR tube that has to be stretched.
As to #8 that is the Valve Assembly Solenoid
Sam
Old 11-26-2014, 01:01 PM
Stevebsy's Avatar
Administrator
Thanks to those who have ordered.
Still need one more though...
3 more early discount sets available.
I'm going to take my car apart this weekend, so I hope that other order comes in from one of you so we can get moving.
'20 Honda Ridgeline
Old 11-26-2014, 01:49 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Can anyone suggest other maintenance that will be worth doing at the same time. If the existing gaskets stick and the manifold has to be fully removed things like PCV valve, IRIS o-ring installation, small hose upgrade to viton material etc. Worth while? Anymore suggestions?
"Peace is the flower of justice."
Old 11-26-2014, 06:27 PM
If you can provide a walkthrough when you do yours I will buy a set
I would check out your knock sensors. Might be cheap insurance to do them anyways.
1994 SVX LSi
2008 Legacy 3.0R
Old 11-26-2014, 06:44 PM
Black01scoobyrs Black01scoobyrs is offline
How thick for the TB spacer? Also 8mm?
