Old 12-20-2007, 07:33 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Door Panel Removal
Anyone here taken off the door panels? Well its not actually taking them off, its getting them back on properly. Is it much of a pain?
Old 12-20-2007, 07:37 PM
What do you mean by door panels? The interior panels? The plastic exterior piece?
The interior is fairly easy, just make sure you get the screw under the handle (pop off the plastic cover in there and you'll see it) and then it's the normal remove some screws and pull/pry off.
Old 12-20-2007, 09:32 PM
Ownbot's Avatar
Yes I mean the interior panels. Just wondered if there was anything special you had to do.
Thanks
Old 12-21-2007, 02:29 AM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Thanks
Only takes a minute to remove, but hard to put it back in place IMO.
You can see the 2x screws on the front of the door, and hidden screws below:
1x under the door handle and 2x under the door pocket(under the felt)
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 12-21-2007, 03:48 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
I took mine off twice to put on some JDM mirrors. pretty easy on and off imo.
-Nate
'92 LS-L Pearlie
Old 12-21-2007, 06:57 AM
Removing the door panel is easy. There are only 5 screws to remove.
Open the door and take out the 2 screws on the front edge of the door panel, near the door hinge.
There is another screw located under the door handle, hidden behind the plastic plate which justs pops out with a small-bladed screwdriver (preferably magnetic)
There are also 2 more screws hidden under the felt mat inside the door armrest. Just peel it away to expose the screws, These are the most important ones as they hold the entire armrest to the door frame. You cannot remove the panel with these screws in place.
Once all screws are removed, just pop the clips around the bottom of the door panel by pulling gently. Once free, lift the entire panel up slightly and pull away from the door frame to see the wiring. There are 2 electrical connectors that must be disconnected; one is for the power window switch cluster and one is for the door courtesy light.
Replacement is the reverse order. The only possible minor hassle is lining up the door lock button to slide into the door panel opening, but usually it is not a problem. Everything will line back up perfectly.
Old 12-21-2007, 07:08 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I think replacing the door panel is easy, it's just lining it up that's a pain. Once it's lined up, it slides right into place, much easier than some of the other's i've had to deal with.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
