Old 01-09-2008, 03:52 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I can't ask you enough... Where are you going to get the amperage you'll need to drive the blower in the first place?
PLEASE DO THIS MATH!!!
Old 01-09-2008, 11:57 AM
cruisen_15's Avatar
like i said in another post, 12 amps x 110 volts=1320 watts
if 1 leaf blower can push 4 psi, at 405cfm that could equal to 1 psi= 100cfm
i think if i do twin blower setup, we could be looking at 5psi+.. and ill use a 3000 watt power invertor to power them, ill worry about where to put them later, i gotta first start my new job and get the money
my idea was to stick 1 blower in each fender well and combine the piping, thats going to be more than 800cfm... so if my engine pulls 550cfm at peak point, then i should be creating lots of boost at idle and moderate boost at 6k rpm
Old 01-09-2008, 01:03 PM
94SubieSVX's Avatar
OOC for a while
I've been watchin this thread, and I'm gonna have to vote FAIL. Just from common sense it seem like it won't work. When the engine sucks up more air at WOT, the leaf blower will probably hinder the airflow.
bLAh
Old 01-09-2008, 01:15 PM
LetItSnow's Avatar
That's fine. However, your car's electrics aren't 110 volts.
* Given 1320 watts and ~14 volts, how many amps do you need?
* What is the maximum amperage output of the SVX's standard alternator?
* Why does your blower fail?
Old 01-09-2008, 03:19 PM
cruisen_15's Avatar
snow, my svx runs on 12 volts, what i ment was that a power inverter sends out anywhere from 110v to 120v and can range from 50 watts to 3000 watss and higher... if i buy a 1500 watt power invertor, thats enough to supply 12 amps, i could do 2 blowers and buy a 3000 watt inverter...
Old 01-09-2008, 04:38 PM
LetItSnow's Avatar
I give up.
You'll be next.
Old 01-09-2008, 04:50 PM
wawazat??'s Avatar
Yeah, I'm still around
Have fun.
Down to none
Old 01-09-2008, 05:07 PM
cruisen_15's Avatar
sorry snow, but im not following?? what do you meen "i give up" and "you'll be next"??
Old 01-10-2008, 08:40 PM
cruisen_15's Avatar
ive changed props from the casual leaf blower type to an actual fan blade, there was a big diffrence, this prop is lighter and blows more air, i will have to custom make a casing in my metal shop at school to see how much psi it will give...sounds better than the other prop, sounds more like a mix between turbo and s/c...
Old 01-10-2008, 09:16 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Old 01-10-2008, 09:23 PM
cruisen_15's Avatar
lmao, why do u have to always shut me down, that wasnt funny with the emote boxer!!!!
Old 01-10-2008, 09:33 PM
Boxersix's Avatar
Truth hurts.
I (we) am trying to help you avoid wasting money on something useless and you just don't get it. I do this line for work for a living and am not going to bullsh!t you on the facts.
Old 01-10-2008, 09:39 PM
Nevin's Avatar
Nevin Nevin is offline
No one is taking your idea seriously because it is not a serious idea.
The only one who hasn't figured that out yet is you, and you act like we're all out to get you. We don't WANT you to fail, but you keep telling others (who actually know what they're doing) that they're wrong and that you're sure that in your case it will work.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 01-10-2008, 10:06 PM
There are countless inventions and breakthroughs that came about despite some explicitely telling the inventor/whatever that it was impossible. Once upon a time flight was impossible for humans. Speeds over 100 MPH would make you turn inside out. Stuff like that. So never give up on an idea just because someone SAYS it's impossible.
However, this idea has been repeatedly proven to be impossible, pointless, and destructive to your car should something go wrong, by many sources. Somebody saying it's impossible is just noise (or selectively darkened pixels on a screen), but someone proving it won't happen is fairly definitive.
Old 01-10-2008, 10:20 PM
cruisen_15's Avatar
ok, i understand what you are all saying, ill just stoop asking/ working on it
