Old 11-23-2007, 11:13 AM
Wikedjuggalo's Avatar
Rebuilding
Proper Tire Rotation
O.k, I want to rotate my tire, by myself. I noticed my front tires are getting worn more then my rear, and before someone jumps on me, my car is FWD and if it was AWD I would not have uneven wear. I need to know the proper rotation pattern to go. My tires haven't been rotated since I got it as far as I know. I have put 5k miles on them now and like I said I noticed the front tires are worn more then the rear.
So my question is what is the proper rotation for this car .
Old 11-23-2007, 11:19 AM
I have heard many different ideas, but the one I would go with is front to back and back to front. Same side, just front to back. If the tires are directional, that is the only way you should do it. Good luck.
Old 11-23-2007, 12:14 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Normally, you rotate your tires every 6,000 miles, so you are just in time. One way to remember is to rotate every other oil change.
Old 11-23-2007, 12:15 PM
Yep, what ^ He^(Earl) said!
Old 11-23-2007, 02:27 PM
Rebuilding
O.k so I just got done. Using my jack and spare tire and some spare time. They should have been done awhile ago but. Also I noticed a big difference in thread.
Old 11-23-2007, 02:57 PM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Tires
If i am correct you have to go front to back or back to front if you were to criss cross them the wheels would be backwards, They are directional wheels ....
Am i correct on this????
Old 11-23-2007, 02:58 PM
AJ4U2's Avatar
DID you go see the 97 at crown dodge yet?
Old 11-23-2007, 02:59 PM
Rebuilding
no, I might go do that right now will be kinda sad as I can't buy it >.>
and as far as rotation yeah, I did Front to back , Back to Front. Did you have a chance to rotate them before I got it from you because of the tread wear is that bad I fear, Alignment is needed.
Old 11-23-2007, 03:01 PM
AJ4U2's Avatar
I was going to but with being stolen 2 times and in a wreck besides sort of made me stop.
Old 11-23-2007, 03:05 PM
Rebuilding
Well I got free time and gas in the tank I am going to go and look at it for everyone else interested. I'll report back.
Old 11-23-2007, 03:08 PM
Make sure that you reset your tire pressures.
Old 11-23-2007, 04:05 PM
Rebuilding
30 front and 28 rear right? Also AJ4U2 they sold it 2hrs before I got there.
Old 11-23-2007, 05:57 PM
I don't remember what it is on a FWD, but on the AWD Subaru recomends
33psi front and 29psi on the rear.
Its listed on the tag on the drivers side B-pillar, where the door lock striker is located.
