Old 11-17-2007, 10:03 PM
bcpianoman bcpianoman is offline
Timing belt wear?
This question will probably win the dumbest question of the month competition but here goes anyway. When I bought my SVXs I didn't get any maintenance records so I have no idea if and when the timing belts were changed. Is there an easy way to find out how much wear is left on them?
Old 11-17-2007, 10:19 PM
Not really. To inspect it you have to remove the plastic timing cover (that black plastic thing on the front of the motor.) In my case I'm just going to assume it needs doing and replace it. The motor needs lots of work anyway.
Old 11-17-2007, 10:37 PM
crazyhorse's Avatar
242,000 mi on oem trans
The only sure way to know how much life is left in a t-belt is to change it yourself.
That said, the EG33 is a non-interference engine, so if the belt breaks, it shouldn't do any internal damage.
"42"
Current Stable By Age:
Old 11-17-2007, 11:54 PM
kwren's Avatar
kwren kwren is offline
I would just change it!
Only one belt and not a tough job.
Old 11-18-2007, 01:43 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
I got mine changed the other day. Cost me a fortune. I have got to start learning more about cars.
Old 11-18-2007, 03:56 PM
94SubieSVX's Avatar
OOC for a while
It took me about 4 hours to do mine. That was because when I was putting the T-Belt back on it kept jumping teeth/or the cams would spin away from the point they needed to be in(Making them turn to the right spot was the worst, trying to turn them by hand). I spent about 1/2hr trying to get it to stay on right.
bLAh
Old 11-20-2007, 01:32 AM
kwren's Avatar
I use the plastic ties!
Put the belt on close to where it goes and move it to the right notch on one pulley... fasten it in the right place with a couple of plastic ties on each pulley Spread them a bit but position them so the pulley can move enough to get in place. do the other side. Turn the crank shaft to get it in the right notch. this gets real easy!!
Works easy for me
Good luck,
Keith
Old 11-20-2007, 12:32 PM
94SubieSVX's Avatar
OOC for a while
Works easy for me
Good luck,
Keith
That's exactly what I did, took me about 15mins to think of using zip ties though Once I did that, it was a piece of cake getting everything back together.
bLAh
Old 11-20-2007, 12:50 PM
dcarrb dcarrb is offline
I doubt there's any way to know how much life is left in the timing belt, but if your car has typical mileage in the low to mid-100s and the front of the engine is leak free, it's a safe bet that the front seals have been changed in recent years, and whoever did that work probably replaced the timing belt while they were in there.
That's probably. In short, if the car appears to have been well maintained, odds are it was.
dcb
Old 11-25-2007, 09:24 AM
BenSVX BenSVX is offline
More timing belt questions
I am picking up my second SVX this weekend and the owner does not have maintenance records either...What can I expect to spend on a timing belt install? I see on E-Bay our timing belt available from "Eastern imports" for $80 and another company for $220.
Thanks.
P.S. Yes, I am excited. And yes, feel free to make an offer on my current SVX. Selling it so I can have a 5spd.
Ben
92 Graphite LS-L Touring (136k miles) #4143
5 speed, ACT clutch, Sparco R-Speed shortshifter, Ecutune v1, Stebro exhaust, PWR rad, 18" Motegi Racing FF15 wheels wrapped in Falken Azenis, Alpine 9833 MP3/CD with Alpine 3ways in front, MSW G-lateral drop springs, ss braided brake lines, d/s rotors, 9005 headlight mod, Celcius mod
92 Ebony LS-L Touring (125k miles) #7328
smallcar shift kit, Panasonic MP3/CD, Remote starter with security
For Sale: http://www.subaru-svx.net/forum/show...370#post501370
92 Claret LS-L Touring (Sold - 1998)
The first car I ever drove.
Old 11-25-2007, 01:47 PM
kwren's Avatar
better deal at subaru.com
Thanks.
really......
Old 11-25-2007, 03:31 PM
really......
Ben really has every every reason to be excited. It would appear that he has made a good buy and it is always exciting to have a new toy.
Ben, congratulations, do a search and see if you can do the job yourself. You will have a big advantage in having two cars so that you need not hurry the job. You can call for assistance if you are stuck or as the job progresses. You can rest assured that help will be available here where you are among friends.
Cheers, Trevor.
