Old 02-20-2006, 11:38 AM
The Molinator
SEAN emailed....
Sean emailed me back...saying the first set of cracked/sliding gaskets on the phenolic spacers with (adhesive) attached gaskets appeared to have been abused (tightened too much, I guess)....[by the mechanics who did my head gasket job a few months ago.]
BUT, he acknowledged that I obviously took care (and had the correct torque spec for the intake bolts) when installing the second set of spacers with attached gaskets...SO, he is sending me a new plain set of Outlaw phenolic spacers which I will install without sealer and Subaru gaskets.
Sean has been very understanding and classy with his response to my spacer problems!
THANKS! I'll let you know what happens THIS time!
Jim
Old 02-22-2006, 01:45 AM
The Molinator
2 gaskets short....
Now just waiting for SubaruParts.com to send me 2 more intake gaskets so I can try assembling with no sealer (or adhesive)! If it doesn't work...guess I'll have to sell it to an enemy...and then buy a new Ferrari...
OHHHHHH!...I guess I'm just a couple hundred thousand short...oops! Let's make this work.
I'll let ya know!
Jim
Old 05-03-2006, 02:47 PM
Cappy Cappy is offline
Formally Capuano
I've been thinking of doing this mod myself, since I have to swap out my knock sensor 2 anyhow. It sounds like I need to order the plain spacers with no adhesive on them from Outlaw, along with two sets of gaskets from Subaru. Should that do it for me? I have a torque wrench, so I should be OK there. And I don't think I need any adhesive for the gaskets, do I?
Cappy
'94 LSi Barcelona Red 158,000 miles
'92 LS-L Dark Teal 47,000 miles
'95 Olds Acheiva 104,000 miles
'85 Audi 4000 135,000 miles
'87 Supra 129,000 miles - 2nd JDM engine
Old 05-04-2006, 03:24 AM
The Molinator
SPACERS....Gaskets...???
I replaced one side (so I wouldn't have to take off the driver's side [AC tube - and drain AC of freon]) with plain spacer and two Subaru gaskets without adhesive...
It seems to be working...I'll let you know..as time goes by... [This was difficult to do since gaskets are not part of unit...It's easy for a gasket to get bent into an intake hole when sliding into place....BE CAREFUL!]
Have Fun! Jim
Jim
Old 05-04-2006, 07:53 AM
Formally Capuano
Thanks Jim,
Is it a given that I'll have to remove the AC tube to lift the collector 1/4" on my '94? It sure looks like I've got more than enough room to fit a spacer in on that side & still be able to thread the bolt. If I gotta do all THAT I 'm not going to bother. I just figured if I have to remove the collector to change out my knock sensor anyhow, I could easily do this mod while I'm at it.
Cappy
Cappy
Old 05-04-2006, 06:16 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
this seems like a dumb question but what do these spacers do?
- John
Old 05-05-2006, 07:26 AM
They are an insulator to keep engine heat out of the intake manifold.
They actually work.
Colder air can give an engine more power.
Old 05-05-2006, 07:33 AM
Formally Capuano
Well, from what I understand, they provide a thermal insulating barrier between the intake collector and the engine block, thus preventing the heat off the engine from getting up into the intake/collector. The idea is to keep the air cooler as it enters the engine, thus providing a horsepower increase, especially after the engine is hot. They claim a 4-8hp increase. I'm not sure I've ever read any "glowing testamonials" about them, but I figured if I had to remove the collector anyhow, this would be a fairly painless mod, and hey, a few extra ponies is never a bad thing.
Cappy
Cappy
Old 05-05-2006, 08:42 AM
Suby Fan's Avatar
ohh ok sweet next dumb question is where can i buy them?
- John
Old 05-05-2006, 09:05 AM
www.outlawengineering.com
Old 02-18-2007, 04:27 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
They're no longer listed on the website... have these been discontinued?
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 02-18-2007, 06:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I don't believe they ever were listed...not enough of a market...just give Sean a call.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-05-2007, 01:23 PM
So.... they DO make them, they just don't list them on their website? I have to call for them to send me some, or do they have to make them?
Old 03-05-2007, 05:31 PM
sicksubie's Avatar
Just call and ask for Sean (I think). I just got mine last fall for $107 shipped.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-11-2007, 09:26 PM
So the idea is that they are just a thermal barrier. Is there no gain from creating a longer strait shotgun, increased velocity type thing "tunnel ram" effect? What is the HP to $ from these anyway? Just curious since I have my intake off now, awaiting gaskets and stuff.
blk 92' LSL w/ average mods
