Old 03-08-2008, 08:57 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
cant get into trunk!?!?
i just bought a 92 svx and it has a new trunk lid on it with the shaved key hole. well i must of acidentally hit the little thing inside the trunk to lock it or w/e, i guess its a bypass or something.? well anyways now i cant get into the trunk, and the back seat will not go down, does the bypass do that too? i was woundering if anyone has any ideas or had to do this before? i have a $700 system in there so i gotta get into it. haha
Old 03-08-2008, 09:15 PM
It's Just Eric's Avatar
Missing in action
hmmm...the rear seats have a lock that is accessable from in the trunk...If you have a clothes hanger, a few pictures, and a TON of time, you can slide the clothes hanger behind the seats into the trunk, and acess the seat lock on the back side of the seat. Once thats unlocked, you should be able to get into the trunk, and from inside you can unlatch it and get everything set up correctly
R.I.P Cool Signature.
Old 03-08-2008, 09:31 PM
Yeesh. Note to self: Don't screw with the "Cancel" lever. Uber note to self: Don't lock the seat.
Old 03-09-2008, 04:30 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Good luck with that. I shut the keys in there once, with both levers in the cancel position. It's really hard to get into. I never lock the seat anymore.
If you don't have a keyhole, your only option is to try and move the lever on the back of the seat. It's about 3 inches below the button and you have to move it towards the right side of the car.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-09-2008, 08:49 AM
newkid17's Avatar
lever?
is the lever like on the seat or is it couneter sunk into the seat? and what works best? a cloths hanger?
Old 03-09-2008, 09:57 AM
This is somewhat destructive but if you pull up the speaker grill, you may be able to remove the speaker. Then you can reach in to unlock the back seats.
Old 03-09-2008, 11:21 AM
If you need a picture of the latch on the seat, let us know. Maybe I can get one for you.
Old 03-09-2008, 12:10 PM
Another possibility is to pull out the bottom rear seat. You can find the pull levers at the base of the seat where it meets the carpet.
Once the seat is out you will see 2 bolts on each side of the seat back at the bottom. If you take those out, the bottom of the seat back may move enough to allow you better access to the lock lever.
The lock lever panel has two parts; Looking at the panel from inside the trunk, the lock switch is on the left and the seat release is on the right.
Looking from inside the trunk, the lock lever is pushed towards the right to lock and to the left to unlock. So from inside the car you want to move the lever to the right (unlock)
I NEVER lock my seat backs on these cars. On my son's pearlie, I filed down the trunk cancel lever to a small nub that I can operate with a screwdriver if needed. There is no way to accidentally trip this lever with this modification.
Old 03-10-2008, 05:37 AM
newkid17's Avatar
thanks
thanks alot guys, i did manage to get it open somehow...lol with a cloths hanger and a little pations.thanks for all your help!
Old 03-10-2008, 08:20 AM
It isn't stock now! ................
Old 03-10-2008, 08:46 AM
I was going to secure a zip-tie around the latch above where the base of the cancel switch went into the latch itself to keep it from being pushed up...
but my Dremel did such a nice job! Same shape as the original, only a lot shorter... looks stock to me.
The day-glo fluorescent orange strip I have on the cancel lever of my Polo isn't stock either. It's there, not to remind me to make sure its in the down position, but to keep me from hitting my head on it while I am in the trunk.
