Old 02-27-2008, 06:02 PM
snofrek's Avatar
snofrek snofrek is offline
SubyFREAK
Send a message via MSN to snofrek
Exclamation what do i need to keep for the 4.44....?
i think i have found a 4.44 tranny and rear diff. so what do i need to save off the car that the tranny and diff are comeing off of so that it will fit on my 92 SVX? and also is there anything special that i might need or have to do to make the tranny bolt on right to fit my car?!......
Old 02-27-2008, 06:09 PM
nextse7en's Avatar
Graphic Artist
You need to keep your rear diff, you will need to swap out the 4.44's internals into your 3.54 housing while retaining the LSD bits of the 3.54.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-27-2008, 06:13 PM
snofrek's Avatar
SubyFREAK
another guy says that i need the rear diff that is for the 4.44 cuz it has to keep the same gear ratio? and u dont switch trannies, u just switch out internals? i thought u switched the tranny and rear diff?
Old 02-27-2008, 06:51 PM
nextse7en's Avatar
Graphic Artist
You DO get the 4.44 rear diff, and swap the internals into YOUR rear diff.
SVX axles wont mate with a normal 4.44 diff, and the 4.44 diff you are getting does not have LSD.
Swapping the 4.44s rear end into the 3.54 rear end housing and ring gear fixes this problem.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-27-2008, 06:57 PM
snofrek's Avatar
SubyFREAK
-Patrick
ok cool, that makes sence! im assuming its the same for the tranny too? o and im guessing that when i take out all the old parts, the 4.44 parts will all fit in the housings all without any troubles too?! i hope!?
Old 02-27-2008, 07:50 PM
nextse7en's Avatar
Graphic Artist
Don't need to replace the front diff, the axles just plug in the 4.44.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-27-2008, 07:54 PM
snofrek's Avatar
SubyFREAK
-Patrick
ok so i take out my tranny and put in the 4.44 tranny, and then just replace everything in the rear diff with the 4.44 parts?! and when i do replace the rear diff parts with the 4.44 parts, they will go in without any problems?!
Old 02-27-2008, 09:58 PM
nextse7en's Avatar
Graphic Artist
Check SVXfiles locker (OT) for details, also the how to section are already provided in great detail.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-27-2008, 11:53 PM
snofrek's Avatar
SubyFREAK
Thumbs up
-Patrick
thanx pat! that helps alot!!!
Old 02-28-2008, 10:06 PM
-Patrick
Thanks, Pat!
Just saw this now.
Been in the garage AND at deaths door.
BTW, the how too is in my signature.
If you have a question, call me.
304-738-0012
That Guy keeps coming back!!!!!
Old 02-28-2008, 10:12 PM
ROFLMAO.... ya know, I can think of a few people who woulda been done by now
Old 02-29-2008, 08:16 AM
nextse7en's Avatar
Graphic Artist
Snofrek,
If you don't mind the 3 hour drive, you could bring the car over here to the rainy Willamette valley and hondasucks and I could slap that puppy in there for not too much moolah.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-29-2008, 04:52 PM
snofrek's Avatar
SubyFREAK
Exclamation
Snofrek,
-Patrick
it will take me 8 hours to get to Willamette Valley, assuming that you're talking about the Willamette Valley in Oregon? i live in Boise, ID. and ok i found a tranny and rear diff off a 96 subaru outback, the 2.5L, THAT IS THE 4.44 FOR SURE, CORRECT?!?!?! cuz i can get both for $250!!!
Old 02-29-2008, 05:36 PM
give us the trans code off the bellhousing by the starter
Old 02-29-2008, 08:09 PM
snofrek's Avatar
SubyFREAK
ok, ill get that as soon as i get back and look at it.
