Old 10-07-2011, 07:26 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
WTB: Factory Alarm System (S.A. TX)
I'm looking for a factory alarm with the dash button.
It's for a '95 so it has to be out of a '94 or newer (they are mounted in the trunk instead of under the dash).
I'll update this with a picture of the dash button I'm talking about and the location of where the unit would be in the car.
Edit: Pictures
Security button:
Alarm unit location:
Thanks!
-Dustin
Old 10-07-2011, 09:37 AM
Re: WTB: Factory Alarm System (S.A. TX)
Any security module will work. They all have the same connector whether it is the early single airbag car with it above the glovebox or the later with it mounted on the trunk panel like yours.
Old 10-07-2011, 10:36 AM
odepaj's Avatar
Killer of threads
How sure are you about that?
I only ask because I'm not sure if the plug in my picture is actually the plug for the module (there were a few others in the same general area).
If they are the same then thank you for making my search much easier!
-Dustin
Old 10-07-2011, 10:38 AM
I'll confirm that they are the same. I've used one's from the trunk deck up behind the glovebox.
Old 10-07-2011, 10:40 AM
odepaj's Avatar
Killer of threads
Awesome!
Thank you both for the info!
I'll have to go dig around in the parts car for the things I need.
This thread can be closed now
-Dustin
Old 10-07-2011, 11:36 AM
And I have used one from a 92 in my 94.
Also, even if the car didn't have the security module, it should still have the plug for it. At least the US ones.
Old 10-07-2011, 10:51 PM
Yep, This type security was a US only option and was installed at port.
Also, look at the sig, I think I would know if something was interchangeable between early/late models
