Old 06-10-2011, 12:31 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Front knock Sensor (1)
Need one knock sensor for the front, by the alternator.
Hopefully this'll cause my car to lose it's misfire and shakiness.
Old 06-10-2011, 04:49 AM
Re: Front knock Sensor (1)
Rock Auto has them for $28.
Old 06-10-2011, 06:38 AM
Chuckls's Avatar
Designated Asshole
oh reary? Thank you!
Old 06-10-2011, 07:58 AM
NP, do a search for "rock auto discount code" to save 5%.
Old 06-10-2011, 08:27 AM
Are you sure it's a knock sensor and not a faulty spark plug wire/connection...that was my issue, switching out the plug and resolved the problem...GL
Old 06-10-2011, 03:22 PM
Chuckls's Avatar
Designated Asshole
replaced all my plugs about 50miles ago.
Old 06-10-2011, 05:30 PM
Maybe one of the new ones started off bad.
Old 06-10-2011, 05:54 PM
Chuckls's Avatar
Designated Asshole
Im hoping that by replacing all my valve gaskets, and the front knock sensor(which has a crack in it) will resolve this..if not, I'll look into finding out which plug is being a pain in the buttocks.
any other suggestions?
Old 06-16-2011, 04:43 PM
Chuckls's Avatar
Designated Asshole
How can I get it out?
Old 06-16-2011, 04:54 PM
Cam Cam is offline
From the looks of it, a combo wrench should do the trick...
If you got a camera down there I am assuming you can fit your hand.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-16-2011, 06:58 PM
Chuckls's Avatar
Designated Asshole
iphone, and i can BARELY get my hand in there. 12mm combo wrench is just a bit too short. Plus, the sensor thats in front of it where the knock sensor plugs in, is in the way.
Old 06-16-2011, 10:19 PM
Cam Cam is offline
Did you remove the alternator?
Cam
'92 Ls-L Dark Teal
Old 06-17-2011, 12:19 AM
Chuckls's Avatar
Designated Asshole
yes..I cant get the bolt to budge
