Old 07-12-2009, 04:38 AM
Elliott's Avatar
Elliott Elliott is offline
Contemplating dual exhaust.
My car basically has no exhaust on it now, the previous dufus cut it off not far after the manifolds and put about 8' of straight 2.25" pipe on each side with a pair of turbo mufflers mounted right under the rear suspension. One side fell off on the drive from his house to the shop after I bought it, apparently sheetrock screws and coat hangers don't make good exhaust attaching hardware.
I searched for pictures of dual exhaust installations, but only found drawings and a nicely done system sitting outside the car. I'd like to see one installed in the car for inspiration, I have an idea of where everything can go, but seeing it done will certainly help. I'm mostly considering duals because I don't feel like making a Y-pipe. I believe the pipe coming from the manifolds is 2.25" and I will be using the 2.25" Turbos since they are brand new and only slightly banged up, there will be no catalytic converters and I would like to keep the stock tips.
So, if anyone has pictures of installed dual exhaust systems, I will be very grateful.
Old 07-12-2009, 08:12 AM
longassname's Avatar
Just some dude.
Re: Contemplating dual exhaust.
ok, 6:30 Sunday morning and you are contemplating your exhaust. I think it's fair to say you are taking this seriously. I'm going to guess the drawing you found was mine and the photo you found was of my system with the x-pipe rather than the x-muffler.
If you do the dual exhaust I would definitely suggest the x-muffler over the x-pipe but I would rather steer you a different direction ( I think I made a drawing and posted a picture of this too). Cut out that remaining 8 inches of oe pipe left on the flanges which bolt to your exhaust manifolds. It is double wall and has a very small id. With it removed the id of the flanges is actually about 2.25". Use 2.25 tubing from the exhaust manifold flanges and a pair of 2.25" standard magnaflow cats--one on each primary tube. Don't worry about a secondary cat. Go straight back to a magnaflow 2 in 1 out muffler mounted in the middle where the oe secondary cat and resonator were. The muffler should be a 2.25+2.25 in to 2.5 out. Run a 2.5" tube back to an OE muffler.
That's the system I have on the pearly I have my mom driving around. It doesn't have any hint of resonation at any time. It's quiet. It sounds good. It performs well. I just sold a basically new oe muffler to svxfiles. You can buy it from him.
Old 07-12-2009, 09:05 PM
jokethis89's Avatar
jokethis89 jokethis89 is offline
95 Laguna Blue 5 Speed
Send a message via AIM to jokethis89
Thumbs up Re: Contemplating dual exhaust.
I say go for it!
I love mine:
Old 07-12-2009, 11:35 PM
subbieatnz's Avatar
I heard some one say that the SVX pace car has dual exhaust? If this is true any one got pics of it?
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 07-13-2009, 12:03 AM
BoxerFanatic's Avatar
Does the differential cross member exclusively favor exhaust routing only around one side, or would it possibly allow a split to both sides?
a symmetrical system would be very cool, but perhaps not technically important, that far back in the system.
I still think a true dual system with some exhaust valves that either engage, or bypass the rear chambered muffler, would be a heck of a thing to try, hooked to a switch that allows open, closed, and automatic tied to engine demand somehow.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-13-2009, 03:02 AM
From the rear of the car
From the front
Old 07-13-2009, 04:42 AM
subbieatnz's Avatar
From the front
What did it sound like
1983 RX Silver Grey
Old 07-13-2009, 04:52 AM
It was so quiet, you couldn't even hear it running....
That may be more due to the lack of a fuel tank than because of the exhaust though????
Old 07-13-2009, 05:09 AM
Elliott's Avatar
I like the way it is done in the pace car. I'm definitely trying to do this as simple as possible.
Is the brace under the differential missing on the pace car?
Old 07-15-2009, 09:44 AM
jokethis89's Avatar
Yeah I would love to see how they did that bracket, I tried to go around either side but it would have been waay too low.
Old 07-15-2009, 10:52 AM
Elliott's Avatar
They seem to have run 2.5" on the pace car, I will only have 2.25". I think I could rework that brace so it goes under the exhaust pretty easily, I'll get under there and look today if I have time.
Old 07-16-2009, 05:38 PM
Elliott's Avatar
I'm going to make a new differential brace that will allow the exhaust to pass beside the differential on both sides. It is almost too easy, a combination of the brace on the car now, the brace from my parts car and some square tubing and I will have more of a crossmember than a brace, it will be 10x stronger than what was there, while allowing the exhaust to run above it.
Anyone know how close the differential comes to hitting the ground when the car is at its lowest point? I know some old Datsun Z cars and Corvettes would smack the differential into the ground on a hard launch. I think Subaru might be a little smarter than that, but you never know.
Old 07-16-2009, 06:43 PM
My car with stock suspension, fully loaded down, will scrape the exhaust over bumps, but that's mainly because my exhaust is all funkied up and hangs lower than it should.
Old 07-16-2009, 06:46 PM
Just get rid of the brace. It is a safety hanger and nothing more
Old 07-16-2009, 07:01 PM
Elliott's Avatar
I was under the impression that it was to keep the differential from moving under acceleration, I guess you know better than I do, this is my first car with IRS.
