Old 11-23-2007, 05:32 PM
Ken92SVX Ken92SVX is offline
Delayed shifting into 4th when cold
I have noticed that occasionally I have a problem that the transmission does not shift from 3rd into 4th (drive) when it is cold out (around 20 degrees Fahrenheit or below); it stays in 3rd with rpm about 3,000 rpm at 55-60 miles per hour. Letting of the gas does not cause it to shift either like in normally does. It just stays in 3rd and eventually shifts after a mile or so of being in third.
This happens in the first mile or two only. Once it shifts for the first time into 4th then it does not have a problem again when starting out thereafter.
Is this normal or does it signal an impending tranny problem?
Thanks in advance for any responses.
Ken
Old 11-23-2007, 06:17 PM
The 4EAT trans that our SVX comes with is not supposed to shift into fourth gear untill the trans oil reached 50°f.
And it is not supposed to lock up the torque converter untill the trans oil reaches 150°f.
So not a problen is being shown. So far!
Ken, this is Subaru's way of telling you that you should stay home when its that freeking cold!
