Old 10-24-2007, 06:08 PM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Wheel Bearings...Front & Rear??
I am sure someone is going to holla at me for not searching this before asking...LOL I can hardly hear when running 60/70 MPH in my car, the bearings are SHOT and im just hoping my hubby is trying to scare me telling me it will weld to the housing and something will come out from under it and the wheel and all will come off and if im running 60/70 I will probably be flipping...(is this true) <p>More importantly can someone send me the best local place and the numbers of the bearings so I can order them or call about them tomorrow. I need to write a check so I would rather get them here. Does the seals or whatever I need come with them and do I need front n rear? Can I get away with doing rear only? (for a couple weeks) <p>Any help is appreciated, I will print it in the AM and order them tomorrow....THANKS!
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 10-24-2007, 06:18 PM
NiftySVX NiftySVX is offline
Search for wheel bearings. You'll need a bearing, 1 inner and 1 outer seal per wheel. ALWAYS have a subaru dealership replace them, or find a shop that has a hub tamer tool to replace them properly or you'll be replacing them again soon. (DO NOT USE A PRESS) Most independent shops won't have this special tool and even if they did they won't know to use it on this car, but it is the only way to fix them properly. Subaru put out a bulletin on this. Additionally, the sealing surface of the axle may have a groove worn in it that will require axle replacement.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 10-24-2007, 06:40 PM
You should realy talk to Tom SVXfiles about this. If you can get your car there, he'll do a great job.
Old 10-24-2007, 07:05 PM
What blue lights?
Wink
LMAO....SOMEBODY learned something from a bearing replacement!
1995 Green
1992 Black
Old 10-24-2007, 08:08 PM
I recently followed a guy to my house with a very bad right rear wheel bearing.
I advised him not to drive it that far, about 100 miles, and he insisted we go all the way to my shop.
WITHOUT STOPPING ONCE!!!
2.6 miles from my home the rr axle boot caught FIRE!!!!!
And fell out from under the car.
The heat was generated by the parking brake shoes rubbing on the inside of the rr brake rotor.
The axle, wheel bearing, rr hub, parking brake cable, ABS sensor, rotor, backing plate, caliper mounting bracket, and more were ruined.
That being said, are you sure its a wheel bearing?
Who did the diagnosis?
Bad tires can make the same exact sound.
Do you have four jack stands?
What county are you in?
I have a list of part #s in another thread and will post it here for you in my next post.
Here is the parts list;
$105.00 labor,
$66.33 for a rear Subaru bearing.#28016PA010
$7.06 for Subaru seal #28015AA070
$8.56 for Subaru seal #28015AA080
$3.50 for Subaru wheel nut #28044AA001
$42.00 for steaming, degreasing, repacking and pressing the new bearing.
$4.28 tax
$236.73 Total.
Old 10-25-2007, 05:29 AM
dcarrb dcarrb is offline
I've driven both of mine for weeks with the faint-but-telltale roar of a bearing going bad, but if they're that loud you really need to have them replaced ASAP. I'd get a second opinion from a good mechanic before replacing both the fronts and rears.
dcb
Old 10-25-2007, 06:20 AM
What blue lights?
Unhappy
$105.00 labor,
$4.28 tax
$236.73 Total.
No bad tires, noise starts at about 40/50 and gets worse, cant stand it at 80. I have extremely sensitive hearing and it hurts my ears. I live outside of Lynchburg Va. I can get jack stands, you coming over? Its raining ask Bobby (sicksubie about rain and coming to my house!) But I can hang! I can use a shop somewhere.
Who did the diagnosis? Um ....ME...well, yall...cause I learn so much from you guys. Just kiddin, tell me what I need to do, its got 150,000 and believe me I would love to learn its NOT the bearings because I DO NOT have the $$$ right now. At this point I need someone to put the belt tensioner bolt back on my black car and put that on the road , but I DO love my green car, and its got my music, and everything like I want it. So help me out here TOm...Oh and Subaru will NOT be doing them either way
NiftySVX..sorry I dont go that way...
1995 Green
1992 Black
Old 10-25-2007, 11:08 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Timken wheel bearings
I did the rears only on my Red 96 Lsi. They werent noisy yet, but just preventative maintenance and peace of mind. Plus we were overhaulin the entire brake system, and it just seemed like a good idea to put in fresh bearings. I went with the Timken brand, which cost me $45 each, and labor was $80 a side. So I got both rear sides done for $250 parts and labor. Great deal, and a great mechanic as well. Stay away from the Subaru dealer, they know very little to none about working on an SVX. If your close to SVXfiles, take it there, you will have peace of mind for sure.
1995 POLO LSI 76K MILES SOLD
Old 10-25-2007, 12:49 PM
A wheel bearing is a wheel bearing. They know what Subaru said about the legacies, which is virtually identical to the SVX, bearings are set up the same way and the replacement method is exactly the same. What is it with everyone hating the dealer so much, anyway?
But by all means take it to SVXfiles, he knows all the tricks. Bob's auto repair probably doesn't care to pay for alldata, and even if they did, they wouldn't bother to look up technical bulletins for replacing the wheel bearing. And even if they did that, they wouldn't buy a $500 dollar tool just for Subarus. But go ahead and press them in, indent the inner race and out of round the knuckle. See you in 20-50k miles for the next set.
Old 10-25-2007, 01:19 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
yep, replaced them a year ago and i'm hearing a slight whining in the rear... trying to tell myself its the tires, but I know deep in my heart its time to add wheel bearings to the standard wear replacement list... oh well at least I can skimp on the axle nuts this time
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 10-25-2007, 03:04 PM
What blue lights?
GEEZ you must work for subie or sumthin. You havenbt been here long enough to hear the horror or $$$$ stories people have been through with the SVX and dealers. As for being identicle to anything I highly doubt it. I went to the dealership and one of the guys selling subies asked me what my car was! Go figure! Im going home from work, its past quittin time...
1995 Green
1992 Black
Old 10-25-2007, 03:12 PM
Hop Hop is offline
Classic SVX
I was hurting in the wallet department when my bearings started acting up. I drove with them screaming for several months. The thing was like driving a sherman tank. No need to bother with the radio because no volume was loud enough to drown out the bearing noise. Fortunately, no harm done. I took them to a local shop and they had them swapped out in a matter of hours. It came up to about $400 for both rear wheels.
Old 10-25-2007, 04:44 PM
svxual's Avatar
svxual svxual is offline
went on fire? ok mine started a slight rear noise was told i needed the bearings as is quite common... but my fire start with the diff bushings and now the mechanic says the diff is fubarbed not the bearings??
Old 10-25-2007, 05:15 PM
I've been in this little community since before this site existed, in fact, for those who remember when we were a yahoo group, i was there. SALES people may not know about the SVX, but the service people will. I have many years of experience and more certifications than I can remember, as well as over 100 college hours in automotive technology. I've personally replaced more wheel bearings than you could count. I don't work for Subaru, I AM TRYING TO WORK FOR YOU SO YOU CAN HAVE YOUR CAR FIXED PROPERLY AND NOT HAVE TO DO IT AGAIN SOON. I do this because I have experience that I don't think many on here do.
END OF RANT
Old 10-25-2007, 07:04 PM
subarufamily subarufamily is offline
you are not ranting, you are saving us money while helping us keep our ladies up and running. wheel bearings are a common problem on these ladies and not replacing them every 30,000 miles is a large help. i have driven on a bad wheel bearings till they made so much noise you could not talk over them which was a bad idea as when they were replaced I also had to replace the hub but is extreme situation
William
