Old 03-18-2008, 10:25 AM
Originally Posted by SubaruSVXCrazy View Post
KNN air filter?
I was about to say No!, this does not qualify because it is not an upgrade.
However, the original poster looked for mods, not upgrades. Why anyone would pay up to $100 to fit an item that was less effective than the OEM filter is hard to figure.
Old 03-18-2008, 11:08 AM
It's Just Eric's Avatar
Missing in action
also add transmission cooler, and power steering cooler (the later for the guys who track their cars)
R.I.P Cool Signature.
Old 03-19-2008, 08:05 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
There ~$50 on ebay. Are they no good?
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 03-19-2008, 09:51 PM
Originally Posted by nextse7en View Post
As per the resistor modification, a power mode switch completely eliminates the need for it any uses existing OEM (albiet hidden to normal folks) shift maps. While I cannot be certain without extensive testing, I believe it pushes the transmission up to full line pressure, and locks the drivetrain into 50/50 power distribution.
Modification to the resistor was my prime suspect for the 1-2 flair that I started experiencing a bit after the mod was done, replacing the resistor with a new OEM spec one fixed the problem.
-Patrick
What was the ohm reading on your replacement resistor?
If you REALLY had a full line pressure, or a 50/50 power split you would know it, and remove it promptly!
I am not trying to harass you, I think the resistor that you installed was of too low a resistance.
Old 03-20-2008, 01:01 AM
Line pressure/torque split.
Line pressure is isolated from the centre clutch by an hydraulic control valve. The resistor has no effect/control, in respect of torque split. This is controlled independently by solenoid “C”, which varies pressure to the control valve, and this in turn varies pressure to the clutch.
Any perceived affect, could only result from more abrupt shifting between ratios, and could not be rightly associated with front/rear split.
