Project I Hate Rust: Phase 1
So I've put a few of these pictures up in other places but figured I should throw them all together. Since my SVX blew a fuel line I've been stripping down the rear subframe to restore/rebuild everything. Phase 1 of this project will be to tackle the functional and mechanical stuff: Fuel lines, brake lines, de-rust and restore the chassis, subframe, control arms and brackets. I Hate Rust Phase 2 will be the exterior body restoration. Time for a photo-journey!
As always, for the big versions of these pictures go to my Photo Post. Subframe down and tank removed: And now for the de-rusting. I'm using a 5 gallon bucket containing a mix of water and sodium carbonate with a 12V, 5A power supply providing juice. Negative to the part, positive to the metal sheet lining the bucket, and a day or so of soak time strips all the rust, grease and most of the old paint off the part. Then a quick scrub with the wire wheel and a wash and it's paint time. Before and after electrolysis: And a before and after paint: Today I got started on the chassis. My plan was to take the rust down with a wire wheel/grinder and then protect it with some POR-15. Seems like it might be a bit more work than that... Upper frame rail. Not bad. Forward frame rail. Bad. Big picture to make the gory details nice and clear. So next step is to go pick up a switch for my welder and some steel so I can start patching things up.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 09-19-2014 at 08:37 PM. |
Re: Project I Hate Rust: Phase 1
I think this thread is going to bring a lot of valuable information. I'm looking forward to seeing your progress.
Last pic looks like your car is resting on four tiny tyres.
I hate rust too !
Good luck - I will follow this thread closely. Kind regards, Tapani |
Got things cleaned up a bit more today. An interesting observation: under the relatively thin outer steel of the frame rail is a MUCH more substantial piece of metal that has almost no rust on it. Makes me feel more comfortable that my repair shouldn't undermine the structure of the car.
Going to apply the POR-15 to the areas that don't need repair tomorrow. Welding to start this week once I pick up my argon. Side note: spot drill cutters are awesome.
And now with POR-15 applied. Quite a process, this stuff. I'm also surprised by how much mileage you get out of it. I bought a pack of 6 4-oz cans and poured half of one into a cup expecting to use about that much on two coats. Turns out I overestimated by a factor of 5 or so. Brushes on very thin and smooths out really nicely. It's very sensitive to any oils on the metal though. There's so much undercoating on some parts of my car that it's continually seeping out, which is making the POR-15 have a hard time covering those spots. But if there's oil seeping out it should be pretty rust-resistant anyway.
